What kind of T-56
Old Jan 11, 2007 | 03:46 PM
will4831's Avatar
What kind of T-56
I am currently converting a 3rd gen 5 speed to a T-56, but first i need to get one. Do i need to get one from a chevy or are they the same for other makes? Probably not, but i had to ask..
Old Jan 11, 2007 | 03:52 PM
ulakovic22's Avatar
The body is the same, but the tailhousing and face plate/bellhousing are different.
Old Jan 11, 2007 | 05:07 PM
will4831's Avatar
ok, so i'll find one from a camaro. Thanks
Another ? though, how much HP/Torque can a stock T-56 take from a camaro?
Old Jan 11, 2007 | 05:09 PM
will4831's Avatar
Also when i was lookin it up there was a M28 and a M29 model i think, something like that, what's the difference?
Old Jan 11, 2007 | 07:32 PM
ulakovic22's Avatar
M29 was only offered in 93 and has deeper gear ratios than the M28. Stock T56's from a F-body can handle a lot of power before they break. Even then you can get it upgraded with cryo/micronite parts or "Viperize" it iwth larger input/output shafts and what not. If you search you can find some good info, also there are T56's for sale all the time so finding one won't be hard.
Old Jan 12, 2007 | 06:14 PM
SABLT194's Avatar
The easiest swap for the 3rd gen is what's called an aftermarket T56. With an adapter it will bolt on to a blowproof bellhousing and put your shifter in the correct location. Call D&D for help.
Steve
Old Jan 15, 2007 | 07:00 PM
will4831's Avatar
thanks guys!
Formula Steve
Sep 19, 2023 08:31 AM
G-BODYT56
Jan 14, 2022 11:14 PM
94Maroz28
Oct 27, 2015 04:38 PM
Hal Fisher
Sep 30, 2015 09:03 PM
karpetcm
Sep 29, 2015 10:08 AM
