t56 input shaft
Old Jan 11, 2007 | 02:57 PM
94_camm's Avatar
t56 input shaft
Went you put it into gear are you suppose to be able to turn the input shaft with your hand?
Old Jan 11, 2007 | 04:48 PM
WinkleTheMoose's Avatar
uh...yes. You should be able to, that means you have a nice flowing tranny. Unless you have engine hooked up to the tranny and the clutch engaged. Then no you aren't.
Old Jan 11, 2007 | 04:54 PM
94_camm's Avatar
ok thanks..
Old Jan 11, 2007 | 05:04 PM
JakeRobb's Avatar
Super Moderator
Um, if the engine is not hooked up or the clutch is disengaged, then why does turning the input shaft have anything to do with the engine's flow?
Ericksd
Jan 20, 2016 06:07 PM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
colts0455
Sep 27, 2015 01:07 PM
