Pop Pop pop
Old Dec 17, 2006 | 01:41 AM
itzkwik's Avatar
Pop Pop pop
have a lt1 355, ported heads , 11.6,1 cr, 150 hp dry nos , stock ported maf,was using the stock 48 mm tb with this combo everything was fine, yesterday I ported the inake for a 58mm bbk, installed the bbk, ran it no nitrous ,fine,. went out tonight no nitrous jet changes, hit the button and bam pop popop, I imediately thought bigger tb more air , lean cond. Went from the 59 fuel jet to a 53 no more pop but short flames out the exhaust and vibration , does computer need to be reprogrammed for bigger tb or just keep playing with jets? oh yeah running 101 unleaded and ngk tr6 plugs
Old Dec 17, 2006 | 09:42 AM
Ray@NitroDaves's Avatar
Ok a little confused here..
150 hp dry nos....Went from the 59 fuel jet to a 53
Is it a wet kit...or dry kit....????
Normally if it is bacfiring through the exhaust you are to rich
Old Dec 17, 2006 | 09:55 AM
itzkwik's Avatar
dry system w/ adj. fuel reg. bypass tee for fuel jet, nos system
Old Dec 17, 2006 | 02:04 PM
roguedriver's Avatar
He's talking about the jet in the T. I'm assuming you have the 67 jet at the nozzle? 59 to a 53 won't richen it up that much, but it will a little. I wouldn't hit it until you get it on a wide band and see what your A/F's are. Maybe even cut it down to a 75 or 50 shot to test it initally. You have any way of scanning it?
Ken R.
Old Dec 17, 2006 | 06:43 PM
itzkwik's Avatar
yea checking the plugs, hell the tech boys at nos said i could run a 48 and 80 to get 200hp , i am wondering if i am not going to have the computer reprogrammed for the bigger throttle body
Old Dec 17, 2006 | 07:51 PM
byrons1502's Avatar
you need to get a wide band reading and see what the car is actually doing
Old Dec 17, 2006 | 08:33 PM
MEAN LT1's Avatar
Agree with the above, I would see what shes doing with a wide band and datamaster.
Old Dec 17, 2006 | 08:54 PM
itzkwik's Avatar
can you guys give me a site or brand and model # of the system your mentioning, have not used that setup yet but geuss i am ready to gat educated The more i know the faster i can go
Old Dec 18, 2006 | 12:07 PM
2000GTP's Avatar
I'm pretty sure he is using this kit: http://www.thunderracing.com/catalog...vid=4&pcid=161 Kit #5176
Old Dec 18, 2006 | 04:20 PM
itzkwik's Avatar
i meant the wideband o2 sys., I am just going to install my noSzle system on it and take offthe dry system, problem solved
Nayr
Mar 3, 2023 08:34 PM
Aaront810
Aug 29, 2020 09:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
Toxintwins
Sep 11, 2015 11:13 AM
