master cylinder question
Old Dec 16, 2006 | 11:21 AM
TJsrh420's Avatar
do you need a scan tool to remove the break master cylinder? i heard someone say that but i don't know how true it is.
Old Dec 16, 2006 | 01:34 PM
foggedz's Avatar
Scan tool? The break master cylinder is held on by 2 bolds. Disconnect the break lines and the 2 bolts and your done.
Old Dec 16, 2006 | 01:40 PM
Are you possible confusing the ABS motor with the brake master cylinder? There isn't a single wire connected to the master cylinder.... why would you need a scanner? On the other hand, the ABS motor assembly may need to have the individual motors "homed" with a Tech-2 (or similar advanced bi-directional scanner) when service is done.
And of course...... "brake" questions belong in "Suspension, Chassis and Brakes", so I'll move the post there.
Old Nov 9, 2008 | 11:22 PM
tlillard23's Avatar
I know this is an old post, but... you would need a scan tool to bleed the ABS on car with traction control.
Chris Anderson
Jan 27, 2015 08:30 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
Hurin
Dec 13, 2014 07:38 PM
siguy
Nov 27, 2014 10:07 AM
