Need advice: To FAST or not to FAST
Old Dec 10, 2006 | 07:45 PM
wicked_95z's Avatar
Im having a dilema. Im trying to decide if the FAST setup is worth it. My current engine harness is showing its age and giving me problems. At the same time I would like to get rid of the opti. These are my two main concerns that I want to fix. If I could fix these two problems i.e. keep my opti up and running and get rid of my gremlins I would be happy with the setup. I dont think my cam requires the kind of rpm that would exceed the capabilites of the stock pcm ( 224/236 .606/.628) so thats not a consideration in deciding. I have heard that there are some features that the stock pcm has that are not available with the FAST, what are they?? From the website, it looks like they have everything covered. I would like to keep the car streetable. Anyone using FAST on a daily driver?? THe big question is can I get rid of the opti, run a conventional distibutor and still have sequential fuel injection?? Would BS3 be a better alternative?? Thanks for any info
Old Dec 11, 2006 | 06:20 PM
engineermike's Avatar
The problem is that the stock ECM controls HVAC, security, gauges, even ABS. FAST won't do that.
Old Dec 11, 2006 | 08:06 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
I personally prefer the BS3 engine managment and it is what I run on my own car.
Running in speed density with a wideband o2 (as you would with BS3) is much safer than running the stock ecm with a maxed maf sensor as it's essentially running blind.
I also have the stock PCM wired in to control everything else.
Old Dec 12, 2006 | 05:02 AM
wicked_95z's Avatar
Well, HVAC is completely gone, VATS is bypassed and the ABS is all gone as of this last weekend. From reading on their website you can add as an option a VSS and a drivshaft sensor if you wanted to go that far
Is there any difference in tuning in Speed Density vs tuning with the MAF i.e. as far as diffuculty
Old Dec 12, 2006 | 06:06 AM
You still have to format and send some sort of signal to the tach and speedo (maybe others) in the dash.
Old Dec 12, 2006 | 07:17 AM
rskrause's Avatar
Moderator
I prefer Electromotive to FAST and use it on my race car. That said, the Camaro works fine with the stock PCM and an impedance converter. What do you hope to gain with the FAST (or any aftermarket ECU)?
Rich
Old Dec 12, 2006 | 06:21 PM
wicked_95z's Avatar
I gotcha Mike
Getting rid of the opti and replacing the worn out engine harness are my main goals
Old Dec 12, 2006 | 09:40 PM
SBCGENII's Avatar
If you go with accell dfi i think they sell a distributer sbc style that lets you go sequential.
Old Dec 13, 2006 | 04:30 AM
wicked_95z's Avatar
Yeah I have been reading up on their dual sync dist. and was looking to buy a used setup but the dfi was already sold
Novo
Jun 14, 2016 02:58 AM
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
damnyankee36
Sep 9, 2015 07:06 PM
