Very strange situation
Old Dec 4, 2006 | 08:58 PM
wicked_95z's Avatar
I'll try and make this as clear as possible. What would cause the pcm to go into power enrich mode before the prescribed % of tps in Tunercat? I can watch my pcm go into pwr enrch mode through datamaster before the prescribed % of TPS for that rpm i.e. @ 3600 rpms it requires 48% tps to enable pwr enrch. According to datamaster, I am in pwr enrch mode at 3600 rpms with only 36% tps. I am trying to track down a stumble both at off idle and while driving
Old Dec 5, 2006 | 02:38 AM
VinceTrifecta's Avatar
A bad MAP sensor (or incorrect manifold pressure - e.g. vacuum leak, etc) would cause this since power enrich mode is determined by MAP sensor reading.
Old Dec 5, 2006 | 05:00 AM
wicked_95z's Avatar
I thought, by looking at tunercat, that PE mode was determined by TPS %.
Old Dec 5, 2006 | 05:32 AM
It's also partly determined on MAP sensor reading. There's a MAP threshold that has to be exceeded before PE mode is enabled.
What's the MAP sensor reading when the PCM enters PE mode prematurely?
I'd also check to make sure the TPS isn't "glitching". Sometimes when they wear out, they'll spike their readings.
Old Dec 5, 2006 | 08:48 PM
wicked_95z's Avatar
In line with the example above, @ 3600 rpms the map reading was 103.3 kpa. I also have switched Tb along with a different tps and a different IAC motor. I guess it could be time for a new MAP sensor. I dont think I have ever changed it in the 6 years and 4 motors I've had in the car
Old Dec 6, 2006 | 01:31 AM
103.3 is definitely "WOT"
Old Dec 6, 2006 | 08:33 AM
Sweetred95ta's Avatar
36% tps and a MAP reading of 103.3 kPa is definitely not right. vgeglia is correct, that is WOT. Are you sure you didn't read the barometric pressure of the atmosphere instead of the pressure on the inside of the intake?
Old Dec 6, 2006 | 02:03 PM
wicked_95z's Avatar
I was looking at the map reading cell on datamaster right under the rpm reading
Old Dec 6, 2006 | 02:20 PM
Do you have a log? I'd like to see it.
Sweetred95ta@hotmail.com
Old Dec 6, 2006 | 06:53 PM
wicked_95z's Avatar
Email sent
Nayr
Mar 3, 2023 08:34 PM
RUENUF
Mar 13, 2016 03:37 PM
93 RedBird
Nov 15, 2015 08:24 AM
tdigger9899
Sep 7, 2015 10:56 AM
Aug 7, 2015 08:52 AM
