NOS Noszle question
Old Dec 2, 2006 | 10:05 AM
gex598's Avatar
NOS Noszle question
I know this system was designed for EFI, but if I hook up a standalone fuel system for the nitrous can I use a low psi fuel pump? I know jetting would change but would it work?
Jason
Old Dec 5, 2006 | 08:24 AM
GetaZforgetGT's Avatar
Use this link to get some tech help directly from the manufacturer.
http://www.holley.com/TechService/TechRequest.asp
Old Dec 5, 2006 | 09:16 AM
Ray@NitroDaves's Avatar
as long as the NOSzle boss are seated in the injector bungs...there is no reason why you couldn't run them off a low pressure system....but I have to ask if you are going to run a stand-alone fuel system why not run it as a high pressure system. That way you don't have to adjust the jetting as much.
Our stand alone systems will support 900hp in high pressure and 1200hp in low pressure...how much do you plan on spraying.
Old Dec 12, 2006 | 08:55 PM
itzkwik's Avatar
yes it will , i have the nos universal with the 45psi jet settings and the, i beleive 7-12 psi setting jet changes
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
kandied91z
Aug 4, 2002 02:53 AM
FilledWithFurySS
Jul 26, 2002 02:00 PM
