Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
What Octane Rating Do You Guys in The U.S Have?
Old Nov 26, 2006 | 09:56 AM
MARKTHOMASBRAND's Avatar
Hi,
Just wondering what the octane rating is in the U.S of your unleaded fuel.
In the U.K regular unleaded is 95 Octane and super-unleaded is 97 Octane.
All the best,Mark.
Old Nov 26, 2006 | 10:50 AM
2000GTP's Avatar
91 and 93 is the premium grade around here.
Old Nov 26, 2006 | 10:59 AM
You can't compare the pump posted octane number in the US to those posted in Europe. Europe uses a different octane rating for posting on its pumps, compared to the US. Europe posts "research" octane. US posts the average of "research" and "motor" octane..... or (R+M)/2
Research octane is a measure of the fuel's ability to resist detonation, as measured through a test routine that most closely simulates "normal" driving... part load operation. Motor octane is measured using a a test routine that more closely resembles high load operation, or what you get when you push the engine to max load/WOT. Research octane can be anywhere from 5 to 10 octane numbers less than Motor octane.
Octane requirement is also heavily affected by altitude, so you may find US fuels rated at 93-octane (R+M)/2 as sea level, and fuels rated at less than 90-octane in Denver, where the altitude precludes the necessity of any higher octane.
Good reference on gasoline:
http://www.faqs.org/faqs/autos/gasoline-faq/part1/
RickRay
Events and Cruise Spots
Apr 23, 2015 02:50 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
karpetcm
Feb 9, 2015 09:21 PM
sleeperZ96BT
Sep 6, 2002 10:22 AM
Red97LT1
Aug 7, 2002 05:45 PM
