Driverside lower front fender sticking out due to improper lifting.
Old Nov 24, 2006 | 06:27 PM
Need4Camaro's Avatar
The car was lifted improperly on the fender tab BEHIND the lifting point. Now on driverside, the lower front Fender has been pushed out far enough to stick your hand in it where it meets the door.... Is there anyway I can fix this or does it need to see a body shop?
Old Nov 24, 2006 | 06:34 PM
1 slo 6's Avatar
u can grad a rubber mallet and bang the lower part of the fender....J/K check to see if there is still a piece of metal sticking down where the lower fender is bolted to. they are usally just bent and need to be straighten that should pull the fender in a fix the problem
Old Nov 24, 2006 | 08:46 PM
sbca96's Avatar
Chances are they broke the bottom plastic tab off the fender, this is how I
fixed mine during my 93 to 98 conversion :
Tom
Last edited by sbca96; Apr 27, 2014 at 06:55 PM. Reason: Picture locations changed
Old Nov 24, 2006 | 10:10 PM
blackz151's Avatar
yep mine bent do to who knows what the owner b4 me did....... do i had to re do them when i re did the fenders for the lambo doors
Old Nov 24, 2006 | 10:18 PM
xstoyz's Avatar
Thats a really clean fix. Nice work!!!
Old Nov 24, 2006 | 10:23 PM
shock6906's Avatar
That's a great way to fix the problem. Mine are nearly broken on both sides so I'm going to keep this in mind when I get under there to fix it.
Old Nov 25, 2006 | 03:25 PM
Tom
Thats a real nice fix! Where did you get the piece for that and what dimensions and where did you drill the holes in relationship from the edges?
Old Nov 25, 2006 | 09:56 PM
sbca96's Avatar
Its a piece of aluminum channel, was in the scrap bin at my work. They got it
through a metal dealer, but I would guess you could find some at Osh, Home
Depot, or Ace Hardware. The piece is cut to the same length as the metal on
the body. The channel was the same length (roughly 1.5") on each flat off
the 90 degree, but I cut the one side down to the same length as the metal
on the body. I used a non broken fender as a guide to figure out where to
put the holes with the channel on the outside. The fender holes were the last
drilled, and were marked with the aluminum bracket bolted to the car, and the
fender lined up in place. Then I drilled the holes through the fender, and had
to notch the edge of the fender for the hole closest to the wheel, so that a
captured nut clip (pulled off the 93 fender front bottom edge) could be used.
You dont want to just thread into the plastic fender as it will break over time.
EDIT : Oh .. as for the hole locations on the fender, I just made sure they are
in far enough to leave enough material, and not so far that the clip wont fit.
That was why I had to notch one edge, the hole was in too far. The clip on
the rear one you can see in the picture, the clip on the front hole come in
from the inside edge, rather then the wheel well edge.
Tom
RUENUF
Mar 13, 2016 03:39 PM
Patricklt1
Apr 24, 2015 06:29 AM
HectorM52
Jan 31, 2015 07:29 PM
siguy
Nov 27, 2014 10:07 AM
98 Blue Formula
Jul 12, 2002 10:26 PM
