100HP the best bang for size?
Old Nov 12, 2006 | 09:59 AM
Z-RATED94's Avatar
Any comments on this? It seems to me after reading many threads that guys running A 100hp shot see the best gains for the size being used. It looks like if tuned correctly a 1 second drop in ET is in order in the 1/4 mile, where a 150 shot might only gain a couple more tenths. This seem about right to you guys?
Old Nov 13, 2006 | 12:12 AM
AutoRoc's Avatar
My 305 engine worked MUCH better with a 100 shot over a 150 shot. Stock heads/cam. It picked up 18mph on a 100 shot and only 20 on a 150 shot. NX Jets used in an NX Stage 6 plate for a carb application. On top of that, the 150 wasn't able to hook in first gear, making it nearly useless and very inconsistant with an ET reduction.
It has to do with cubes, cylinder head flow, camshaft, etc
If you're just playing around, 100hp jetting is a lot of fun, very safe, especially on non-track surfaces. On race day, an extra 50hp can be worth it, even if you can only get .2-.3 out of it.
Old Nov 19, 2006 | 02:52 PM
MeanGreen97Z's Avatar
100 HP jets are what I used on my 97. Worked great. I'm doing the same on this car. Going to build the transmission first.
Old Nov 19, 2006 | 05:08 PM
Vikrel's Avatar
Ive heard the same and agree
93 RedBird
Nov 15, 2015 08:24 AM
RX Speed Works
Oct 1, 2015 10:19 PM
surreybrad
Sep 29, 2015 09:00 PM
autoxr166
Sep 25, 2015 04:21 PM
Jake Bialke
Sep 24, 2015 11:31 AM
