Is there a way to reprogram the V6 PCM for 3.73 gears
Old Nov 11, 2006 | 01:39 PM
zkmfdmz's Avatar
Exclamation Is there a way to reprogram the V6 PCM for 3.73 gears
I have a rear end I want to buy for my 1995 3.4 auto
but the pcm wont recognize a 3.73
how can i mAKE IT WORK???
Old Nov 11, 2006 | 02:01 PM
camarozz95's Avatar
Back when I had a 3.4 I was going to do the same thing. The 3.73's will work, but your right your speedo will be off, and so will your shift points. As far as I know there is no tuning software for the 3.4. but I'm sure it can be done, it's just very hard to find things for the 3.4 especially tuning wise.
Old Nov 11, 2006 | 02:05 PM
zkmfdmz's Avatar
im sure there has to be a way to make it work
i cant find any other good deals on rear ends anywhere
Old Nov 11, 2006 | 02:17 PM
camarozz95's Avatar
I'm Pretty sure there are some guys on here with 3.4's with rear gears maybe they can help you out when they see this.
Old Nov 11, 2006 | 04:47 PM
FunkZ's Avatar
I've got 3.73's in my rear as well, I just live with the speedo error. But then I have a manual. I'm not so sure the shift points will be affected all that much in the auto, I know several people who have done gears without reprogramming. It wouldn't hurt for the 3.4 to shift a little sooner anyway, with the stock cam peak power comes on before 5000rpm and I believe the stock shift point at WOT is like 5300 or so. But if you would want to get the PCM corrected for the gears you can always send it off to Fastchip.com
Old Nov 11, 2006 | 10:34 PM
lucky19's Avatar
I have a 3.8 97 and I took it to the dealer only to spend $80 bucks for them to tell me my 3:73 couldnt be set in the pcm. So i send it off to texas performance speed and they where about to reflash my pcm with other modds i had in it. So speedo is correct and adjusted the shift points.
Old Nov 12, 2006 | 12:07 AM
FunkZ's Avatar
A dealer can only program the PCM for gears that were available as options from the factory.
We have 3.4's, and unfortunately Fastchip.com is the only vendor that offers custom tuning for us. Last time I checked they charged a little over $300.
Old Nov 12, 2006 | 07:15 PM
3800FBL's Avatar
I think www.pcmforless.com will send you a compatable 96 PCM in place of your 95. They also have an excellent special running right now.
Old Nov 12, 2006 | 08:21 PM
AlfredB18's Avatar
I didn't know a 96 PCM (only going to be a 3.8L ECM) was compatible with a 95 and a 3.4L...
Old Nov 12, 2006 | 11:12 PM
FunkZ's Avatar
It's the 97 PCM they will send you to replace the one in a 96 3.8 car.
Old Nov 13, 2006 | 10:59 PM
ImportKILLER's Avatar
They aren't.
Old Nov 15, 2006 | 03:34 AM
Don350k's Avatar
LoLoL
obd1 vs obd2
i wish it was that easy or my 94 would be obd2 now
Don
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
blac94Z
29
Mar 25, 2015 04:21 PM
