Stock Radio problem
Old Nov 5, 2006 | 02:02 PM
Z28Freak86's Avatar
Stock Radio problem
My stock radio the other day started to act funny. I never had a problem with the radio before. What happened is 2 days ago, i installed a new anntenna. As soon as i turned on the radio, it had a bunch of static, so i truned it off. Bout an hour later, i turned it back on, and no volume is coming out. On top of that, it is frozen on one station. As far as i can tell, the only switch that works is the power/ volume switch and the cd eject. Also, the clock doesnt display a time, only the green - marks. It doesnt say that the radio is locked or anything. Also, i put in a cd, but it doesnt play it. Whats ur thoughts on this?
ITs a 1995 camaro with the stock bose delco 2 system
Old Nov 6, 2006 | 07:47 AM
LS1 RULZ's Avatar
Consider yourself lucky it lasted as long as it did. The fact that it crapped out at the same time you replaced the antenna is just a coincidence I'm sure. You can try disconnecting power to it to see if it resets itself. If it doesn't it's time to look into replacing it.
Old Nov 6, 2006 | 08:08 AM
Z28Freak86's Avatar
yea i thought so. i just needed alittle closure i guess by getting another opinion. i'll try reseting the power to it. I kinda like to stock system to be honest. so if it is junk, i'll try finding a stock replacement. Thanks
DirtyDaveW
Dec 1, 2016 05:37 PM
Catmaigne
Dec 25, 2014 12:16 PM
craigffb
Sep 5, 2002 08:17 PM
mjcent922
Jul 27, 2002 12:42 PM
