Whats best size for FMIC ???
Old Nov 1, 2006 | 12:15 PM
AZ2ENVY's Avatar
Im currently looking for a FMIC and was wondering what is
the best size to go with ? I was thinking a 12x24x4 . If not
any suggestions will be appreciated . Thanks
Oh and I will be cutting the front of the bumper out where
the fog lights sit also so there wont be any obstructions
Old Nov 2, 2006 | 05:47 AM
CALL911's Avatar
Contact Bob at EPP (www.exoticperformanceplus.com). He set me up with a killer FMIC for my car (not sure the size, but I think it is slightly bigger than 12x24x4). You will be limited in your search for FMIC's since there really aren't any to speak of made specifically for our cars (LT1's). You pretty much have to find custom ones, and fab up piping to make them work.
Also, you don't have to hack up your bumper if you don't want to. I created an air dam under my bumper directing air to the FMIC, and my IAT's are nice and cool on my car.
Old Nov 2, 2006 | 11:03 AM
AZ2ENVY's Avatar
Thanks I would love to not hack up my front bumper since its new
and repainted You have any pics i could see of the way you have
the air dam set up ? Thanks again
Old Nov 3, 2006 | 03:31 AM
CALL911's Avatar
This is abou the best picture I have. I did cut the space out behind the fog lights because it wasn't too noticable, but I wanted to leave the rest alone. The actual air dam hangs a little low under the front bumper (you can see the metal bolts holding it in place).
Hacking out the entire section where the fog lights are, and the black part in between them will undoubtingly give you the most air flow, and coolest IAT's. However the custom air dam I made still keeps my IAT's plenty cool, and didn't ruin the appearance of my front bumper.
Old Nov 3, 2006 | 03:57 AM
ZBLKHELLRZR's Avatar
I too run a EPP setup but I custom fabbed a few pieces as their kit was intended for LS1's. Wasn't too hard to fab the rest up. I hacked my front end to death because I wanted my accusump to fit and that was the only place to put it. It's not visible now but I haven't taken any new pics either. I cut the support beam and actually mounted the IC to plastic headlight unit and it's reinforced at the bottom w/ some straps. Rock solid and isn't going now where w/ the bracing and piping in place. It also allowed the IC to sit up higher so it's not interferring w/ the airdamn but you can't tell w/ these old pics. The IC is 31X12X4.
Old Nov 3, 2006 | 08:25 PM
cndctrdj's Avatar
damn these things look great
hey zblkhlrzr(sp?) whats that blue thing above your ic
Old Nov 4, 2006 | 04:21 AM
That's a 3qt accusump from Canton. It's tucked up further than that now but no new pics as of yet.
Old Nov 4, 2006 | 09:52 AM
cndctrdj's Avatar
sorry for being ignorant but what does an accusump do ?
Old Nov 4, 2006 | 10:36 AM
97WS6Pilot's Avatar
Here is the one everybody seems to be using.
http://cgi.ebay.com/ebaymotors/4-Cor...41786962QQrdZ1
Here is the piping kit I used. The rubber in these kits is terrible so I used gates hose.
http://cgi.ebay.com/ebaymotors/3-Int...QQcmdZViewItem
Old Nov 4, 2006 | 01:03 PM
AZ2ENVY's Avatar
Thank you for all the help Where can i pick up the gates
rubber connectors at ? Thanks again
Old Nov 4, 2006 | 02:04 PM
Schurters LT1's Avatar
i did the fmic myself.......pics in sig..
Old Nov 4, 2006 | 10:39 PM
97WS6Pilot's Avatar
NAPA has it. I got the 2 ply white stripe hose. It's about $20 a foot.
93 RedBird
Nov 15, 2015 08:24 AM
RX Speed Works
Oct 1, 2015 10:19 PM
surreybrad
Sep 29, 2015 09:00 PM
autoxr166
Sep 25, 2015 04:21 PM
Jake Bialke
Sep 24, 2015 11:31 AM
