Which fuse is this?
Old Nov 1, 2006 | 10:24 AM
micfly83's Avatar
Which fuse is this?
Ok so I installed my electric cutout
and it doesn't work...
but neither does the horn.
I'm guessing I blew a fuse.
Its hooked up to the cigarrette lighter wires, and I dont think that works either...not sure it ever did.
Do you know which fuse I replace and where its at?
Old Nov 1, 2006 | 10:40 AM
2000GTP's Avatar
The cigarette lighter/horn share the same fuse, it is located in the instrument panel fuse block. According to Chiltons, its Fuse #11 and is 25amps. I'm guessing you either have the circuit overloaded with the addition of the cutout, or you have it wired poorly or incorrectly.
Old Nov 1, 2006 | 11:05 AM
micfly83's Avatar
Sounds right
When we first wired it up we matched the wires up wrong on the Cig Lighter, probably blew it.
Old Nov 1, 2006 | 11:09 AM
2000GTP's Avatar
Originally Posted by micfly83
Sounds right
Yep, that will easily do it.
Jeff1904
Jun 5, 2016 05:00 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
z28cam1993
Sep 9, 2015 04:08 AM
RUNMYTA
Jul 15, 2015 07:50 PM
