Heat Shield for Intake?
Old Nov 1, 2006 | 10:05 AM
micfly83's Avatar
Hey guys
So right now I have an aluminum intake for my Z28.
As the engine gets hotter and hotter the intake pipe gets hotter and hotter to the point where its uncomfortable to touch. I'm sure its robbing some performance, and possibly making the engine run hotter?
Is there something I can buy to wrap it up in that will keep the heat off. Like a heat shield or something?
Old Nov 1, 2006 | 10:23 AM
Z28SORR's Avatar
By "intake pipe" I assume you mean everything before the throttle body. I do not know of any purpose built duct for this but there are lots of heat shielding that could be used. For instance, the aluminized insulation that is used for the interior could be cut into strips and formed around the intake, and held in place with aluminum tape. Or header rap could be use and covered with aluminum tape, etc.
Heck, just putting aluminum tape around it would reflect a lot of heat and would be pretty easy to do.
Old Nov 1, 2006 | 11:08 AM
micfly83's Avatar
Yea, everything before the Elbow is aluminum
What would be the best place to go and get it?
Old Nov 1, 2006 | 12:24 PM
Z28SORR's Avatar
http://www.jegs.com/
http://www.summitracing.com/
These guys a popular. You can get tape at the hardware store.
Old Nov 1, 2006 | 12:48 PM
myslowcamaro's Avatar
www.techflex.com also makes a aluminum/fiberglass reflective wrap with adhesive or velcro, they can point you to a dealer too.
Old Nov 1, 2006 | 12:56 PM
micfly83's Avatar
I was hopin for a local store like advanced auto parts that I could just go and buy it at.
Old Nov 1, 2006 | 05:28 PM
jjminch's Avatar
On the s10board a guy actually got out a thermometer and did a bunch of tests on this. Don't remember everything but It basically came out that the air was moving so fast that the temperature of the pipe really didn't mean squat. This was K&Ns logic to using plastic, then they started making metal intakes also.
PCLZ28
Dec 24, 2015 05:19 PM
rjc1629
Jan 27, 2015 10:46 AM
Jan 23, 2015 01:13 PM
Jul 4, 2005 05:00 PM
