On an OBD2 LT1 car, what happens if a rear O2 sensor is bad?
Old Oct 19, 2006 | 01:24 PM
trax's Avatar
Something must be wrong with the wiring harness going to my driver-side rear O2 connector, because the O2 sim there blinks, but my scan tool shows that the voltage never changes. The PCM is showing a code for that O2 sensor (bank 1 sensor 2). The passenger side sim voltage fluctuates normally as it should. If I swap the sims I get the same behavior, so it's definitely a harness issue.
If the PCM is getting a bad signal from a rear sensor, does it make any adjustments to the fuel trim? I would guess that it just uses the front O2's to evaluate the mixture, and then uses the rear O2's to make sure that the cats are working.
Any info? Thanks!
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
