water in power steering
Old Oct 10, 2006 | 03:06 PM
clemsb4c's Avatar
OK I have a question. I was looking to buying this 99 WS6 when I got there the guy said it had antifreeze in the power steering pump and power steering fluid in the radiator. My question is, is there a power steering cooler on these cars? If so is this a common problem and how much would it cost to fix (roughly). The reason is that besides this and the headlight motor being out the car is almost perfect and he only wants $3500.
Old Oct 10, 2006 | 08:40 PM
ReNxWar's Avatar
Re: water in power steering
I'd say either way, 3500$ for a '99 is worth replacing those components. Get the head gasket checked, though.
Old Oct 10, 2006 | 11:13 PM
clemsb4c's Avatar
Well, I checked the oil and it doesn't look milky and the car is running cool. SO I don't think is a head gasket and that doesn't explain why theres water in the power steering pump.
Old Oct 11, 2006 | 06:42 AM
AL SS590 M6's Avatar
Moderator
These cars have an optional power steering cooler in the upper radiator hose. It's an aluminum tube that runs diagonally across the radiator. It's probably broken internally and letting the fluids mix. You'd have to cal a dealer or search for the price.
Old Oct 11, 2006 | 09:36 PM
Greed4Speed's Avatar
The power steering cooler is the aluminum tube in the upper radiator hose. It's right by the radiator. Just like Al described. It'll also have two lines from the power steering system running to it.
Mine started leaking oil into the radiator. GM wanted over $150 IIRC for the cooler. I just got an aftermarket heat sink type trans cooler and plumbed the PS lines into it. That was ~$60-75 for the cooler, fittings, and hose.
Old Oct 13, 2006 | 10:09 PM
TOS98SS's Avatar
I bought my car with the same problem I was quoted 115 for the inline PS cooler I bypassed it for a while and got an aftermarket one also .
Now the problem was that I guess when I flushed the coolent I didn't get it all out because all the hoses I just replaced started to soften and swel I had to replace them again I got a stock z28 upper hose to completly bypass the cooler . I changed all the hoses when I did my cam heads swap the only thing that sucked was the heater hoses were $150
HectorM52
Jul 30, 2017 11:46 AM
mspennyhughes
Mar 1, 2015 03:50 PM
XtremeLt1
Sep 13, 2002 08:50 PM
