RWHP gains from this exhaust??
Old Nov 14, 2002 | 09:49 PM
LBJ's Avatar
LBJ
Friday Iam having a custom 3 inch catback with a 4inch bullet (dynomax) comming off the Y pipe and either...
A) exiting in front of the rear passenger wheel
B) over the axle (not mandrel bent) and out the back with a onesy on the passenger side
Next friday me and a buddy will install mac mid length headers with the mac off road Y pipe.
Old Nov 14, 2002 | 10:47 PM
LBJ's Avatar
LBJ
guess this is the wrong area to post this!
Old Nov 15, 2002 | 05:20 AM
My84Z's Avatar
with the headers and exhaust i will say you'll add close to 20 rwhp maybe alittle more. no exact way to know.
Old Nov 15, 2002 | 01:32 PM
ratio411's Avatar
You might as well dump the stock mandrel bent 2.75" pipes for 2.5" pipes if you don't mandrel bend the 3" pipe. That's how bad non-mandrel pipe restricts.
Jegs carries individual I-pipe parts in 3" mandrel bent for our cars if that .25" means alot to you. They are DynoMax cat-back parts that they can special order. From what I understand it is about $50.
Also, that bullet is going to be very raspy rather than deep sounding with an ORP. The best bullet for what you are contemplating is a DynoMax part #24219 long bullet.
Good luck
Dave
Old Nov 16, 2002 | 12:43 AM
LBJ's Avatar
LBJ
ratio411,
I got the guy to put the bullet on the end of the y-pipe and on the end of the bullet use a 45 degree mandrel bent pipe towards the passenger rear tire.
It sounds great for now! When I add the headers and ORP Iam sure I will end up with a dr. gas X with another bullet to make the true dual exhaust! To keep it on the hush hush side!
Thanks for your response, I got the idea from you in the first place with my own "little" twist.
Thanks again,
Brian
F'n1996Z28SS
Aug 23, 2023 11:19 PM
TitoPR221
May 26, 2015 12:20 AM
May 21, 2015 01:04 PM
BLK1997Z28
May 7, 2015 03:01 PM
