front hub assembly wont come apart???
Old Oct 7, 2006 | 09:45 PM
z28trick's Avatar
im trying to re-pack the front wheel bearings on my camaro but i cant get the assembly apart. i have caliper and rotor off and even the 4 bolts on the back of the thing out. i dont know if theres anything else holding it on there or if its just stuck. any info would be helpful! thanks
Old Oct 7, 2006 | 10:02 PM
razor02097's Avatar
Re: front hub assembly wont come apart???
Im pretty sure they arn't suppose to come apart that they are an assembly. But I could be wrong
Old Oct 7, 2006 | 11:46 PM
OBE1 95Z28's Avatar
Non-serviceable part.
Old Oct 8, 2006 | 02:31 AM
respectirocz's Avatar
non-servicable, does not need to be re-greased
if the bearing goes bad, replace the hub as a unit
Old Oct 8, 2006 | 08:12 AM
The hub can get stuck in the knuckle due to rust/corrosion, but it is replaced as a unit as already indicated. A little "persuasion" will free it from the knuckle. Prepare to lay down $100+ for a new one.
Old Oct 8, 2006 | 05:57 PM
z28trick's Avatar
alrighty thanks!!
96SilverRam
Nov 20, 2016 11:19 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
cyteone
Feb 7, 2015 06:04 PM
1LEThumper
Jul 14, 2003 12:45 PM
