TunerCat... How do I change inject.....
Old Oct 7, 2006 | 04:26 PM
jmangler's Avatar
Hey guys,
I'm new to this tunercat. I have no idea on where to go to change the injector size! Also how do I actually go in and change it on thepcm and up-load the change.... I hook it up and theirs just a ton of stuff that I dont understand. I just have to change the injector size and nothig else.
Old Oct 7, 2006 | 05:29 PM
97WS6SCharged's Avatar
Re: TunerCat... How do I change inject.....
It's listed in the PCM Constants Table. Do a search on your injectors though as some require a slightly different setting than what they are rated for.
Old Oct 7, 2006 | 07:02 PM
jmangler's Avatar
I will see what I can come up with. This thing is so confusing as to whats what. I wish I knew someone close by who can school me on this!
Old Oct 8, 2006 | 06:36 AM
jmangler's Avatar
Hey 97ws6, Any idea where I can start to search? I guess you saying that a 40lb inector may have to be set at 37lbs or 42lbs depending on who makes it..
Old Oct 8, 2006 | 10:24 AM
jmangler's Avatar
Damn I'm a retart! I just realized that is a schooling sesion on Tunercat right up top!LOL....
Old Oct 9, 2006 | 11:36 AM
Sweetred95ta's Avatar
I'm not sure if it says in the sticky, but when you change the injector setting, you have to do a calculation first, which is what 97WS6SCharged was talking about. See Injuneer's post below for clarification.
Old Oct 9, 2006 | 12:42 PM
Not quite.... its not a "simple ratio"... its proportional to the square root of the pressure ratio.
The SVO's are flow rated at 2.7bar = 39.15psi
To get the new flow rate at a new pressure (say 3bar = 43.5psi), you need to calculate the square root of the pressure ratio.... example:
Pressure ratio = 43.5 / 39.15 = 1.1111
1.1111^0.50 = 1.0541
New flow rate = 30 x 1.0541 = 31.62 #/Hr
You may also find that the flow ratings are "nominal".... the stockers for example, are quoted as 24 #/Hr, but they are programmed at 24.9 #/Hr.
Old Oct 9, 2006 | 12:57 PM
Thank you for clarifying that. I've actually used this method before, but I forgot about the sqrt. I thought the SVO's were rated around 39 psi, but my caculations weren't working out. Wasn't making sense.
Old Oct 10, 2006 | 05:10 AM
jmangler's Avatar
Thanks guys! Big help!!
96SilverRam
Nov 20, 2016 11:19 AM
jayblev95
Jun 7, 2015 04:04 PM
mdenz3
May 22, 2015 09:25 AM
May 1, 2015 01:14 PM
NewsBot
Jan 21, 2015 06:10 PM
