ok im an idiot...help asap
Old Oct 2, 2006 | 10:24 PM
Daniel6718's Avatar
ok im an idiot...i was just racing and i went from 3rd to second very quickly and hit the clutch car didnt die or over rev but the clutch petal is vibrating and it grinds going into gear...and at stop lights the car still moves with the clutch petal in...so what did i break or bend?
stock clutch stock car...
Old Oct 2, 2006 | 10:30 PM
davidarel's Avatar
Re: ok im an idiot...help asap
possible syncro damage and throwout bearing not fully disengaging.
Old Oct 2, 2006 | 11:58 PM
Daniel6718's Avatar
how would it be syncro damage in every gear if i only shifted to second...i didnt miss any gear....i just went into 2nd instead of 4th...which means 2nd was prolly going 8000 rpm when i dumped it from 5500 in 3rd to 8000 or so in 2nd, it locked the rear and i hit the clutc quick...could i have bent the clutch fork? or messed up the throught bearing or clutch?
Old Oct 3, 2006 | 12:05 AM
Klypto's Avatar
could be anything
Old Oct 3, 2006 | 12:38 AM
Daniel6718's Avatar
well i just pulled the slave cylinder...and i think about half the clutch fell out...i hope thats it...im goana pull te rest tomaro
Old Oct 3, 2006 | 03:31 AM
davidarel's Avatar
I mentioned the syncro becuase you stated that it grinds going into gear, but it sounds like you found the problem.
Old Oct 3, 2006 | 11:18 AM
Daniel6718's Avatar
Old Oct 3, 2006 | 09:02 PM
respectirocz's Avatar
well there's ur problem
i actually did the same thing a while back
i was showing off the car to my dad on the highway and i was around 4500 in 3rd and accidentally went to 2nd, shot up to around 7grand, my clutch feels fine, i dont hurt my car like that anymore
by the way, i'm guessing this isnt the 94 z28 automatic
Old Oct 3, 2006 | 10:31 PM
Daniel6718's Avatar
lol i have a badass(stock) clean polo green daily...
if you read my first post i did the exact dame thing...
Old Oct 7, 2006 | 08:50 PM
1995greenTA's Avatar
I did almost the same thing in my old car a year ago. I was racing before i had my pro 5.0 and ended up going from second back up to first. The 10 bolt was no more...
Old Oct 7, 2006 | 10:34 PM
Jlo's Avatar
Jlo
PRO 5.0 with Lou's short stick and you're problems will be solved.
Devinfoote87
Sep 4, 2015 05:52 PM
asilomar244
Jul 12, 2015 05:53 AM
james4154
Jun 15, 2015 12:16 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
