steering problems
Old Sep 29, 2006 | 10:30 AM
ColeSmith's Avatar
steering problems
So I went to get my oil changed and to get the car inspected. I bought it roughly a month ago and was planning on racing for the first time last night but come to find our the rack in my steering is broken. They want like $720 or something to fix it. Anyone else had this problem? Is that price high?
Old Sep 29, 2006 | 10:34 AM
TraceZ's Avatar
Re: steering problems
What prompted them to come to that conclusion?
How is it "broken"?
Old Sep 29, 2006 | 11:15 AM
Obviously, it is not "broken" enough to get it to the oil change place.
Old Sep 30, 2006 | 10:14 PM
OBE1 95Z28's Avatar
If you do have an issue with the steering rack, it sells for less than $200 and is straight forward to install.
Old Sep 30, 2006 | 11:40 PM
razor02097's Avatar
did you get an oil change and an alignment? Rack and pinion steering is pretty durable... I have yet to see one break.
Old Oct 3, 2006 | 10:06 AM
ColeSmith's Avatar
yeah but it used to be acop car so I fgured it was from him turning around at high speeds to catch speeders like yall. lol
Old Oct 19, 2006 | 03:22 PM
SpdFrk1990's Avatar
Is there a how to on the steering rack install mine is leaking a lil if I cant fix it ill just get another one at 200 that isnt too bad. How do you get the air out of the system also when installing one. As far as unbolting and bolting up that is strait forward but I never messed with a steering rack before.
Old Oct 19, 2006 | 09:36 PM
OBE1 95Z28's Avatar
Shoebox has a how to to bleed the steering system: http://shbox.com/1/4th_gen_tech2.html#psflush
As far as the installation, the rack bolts to the K member with 2 bolts. The tie rod ends need to be removed from the steering knuckles. The steering gear coupling shaft (connects the steering column to the rack) unbolts from the pinion gear (note: do not turn the steering wheel more than 1 revolution either way when the coupler is removed, your will damaged your air bag coil) and the 2 power steering lines need to be disconnected from the rack (use line wrenches).
Usually the new rack comes with inner tie rods and boots; you can either transfer your old outer tie rod ends to the new rack and buy new ones. Take note of the outer tie rod location on the rack so that you mount them in the same location on the new rack. This will get your alignment close; you should still have the car aligned when you're done otherwise your toe-in will be off.
Old Oct 19, 2006 | 09:54 PM
SpdFrk1990's Avatar
Thanks for the link thats what I needed. Is there a nut to adjust the tension on the rack I think that might be where mine is leaking.
Old Oct 20, 2006 | 10:15 AM
OBE1 95Z28's Avatar
Shoebox's site also has a drawing of the exploded view of the steering rack:
http://shbox.com/1/rack&pinion.jpg
Old Oct 20, 2006 | 10:30 AM
SpdFrk1990's Avatar
Yeh right where it says 32 looks to be where mine is leaking.
Old Oct 23, 2006 | 07:17 PM
SpdFrk1990's Avatar
Got a better look at mine the other day I can show the pics ltr but I think mine is leaking where the rubber hose and hardline crimp together.
Victor Lamb
Aug 26, 2017 02:52 PM
Z28amustangklr
Middle Atlantic
Mar 28, 2015 03:08 PM
mspennyhughes
Mar 1, 2015 03:50 PM
Airplanedoc
Feb 1, 2015 07:14 PM
ro2207
Dec 4, 2014 06:18 PM
