When will it end? (Problems)
Old Sep 26, 2006 | 06:24 PM
brendon444's Avatar
94 camaro z28
Window motors,power locks, trans mount, sway bar links, warped rotors, engine goes out, then opti then icm, then 3 coils, now it seems when everything is fixed trans starts slipping. When do you draw the line to stop dumping in more money. Worst reliable vehicle i have ever owned. If its not one thing its the other with this car. Wonder what will be next. I keep thinking well what else could go wrong, and things keep coming up. I do no abuse the car either.
Old Sep 26, 2006 | 06:27 PM
razor02097's Avatar
Re: When will it end? (Problems)
check the fluid level.
Keep dumping till it runs out of problems or you run out of money
Old Sep 26, 2006 | 07:59 PM
littlbasterd's Avatar
its an old car its gonna have problems, you are complaning about normal wear items..it just sucks they all happen so close to one enother
Old Sep 26, 2006 | 09:33 PM
TraceZ's Avatar
The joys of daily driving a 13 year old car. Buy something newer for reliable daily transportation and keep the Z28 for weekend fun. Or.... dump a ton of money into the Z28 and make it a reliable daily driver. Do a partial restoration on it and replace all the stuff that can go wrong.
Old Sep 26, 2006 | 11:23 PM
sandman63's Avatar
Looks like you got a lemon
Old Sep 27, 2006 | 11:15 AM
Bert02SS
Guest
Posts: n/a
What, the water pump hasn't taken a dump yet? Consider yourself very lucky. The answer to your question: The problems will never end. Buy a newer car if you want to delay the problems.
Old Sep 27, 2006 | 01:05 PM
2000GTP's Avatar
Those are pretty typical problems, as mentioned above, they can be considered normal wear.
Old Sep 28, 2006 | 01:03 AM
Charging TA's Avatar
Its not the age of the car thats the problem...
For example my 30+ year old Charger didnt have one technical problem prior to the start of this "build up"... Ran and drove great.
Old Sep 28, 2006 | 01:39 AM
Heatmaker's Avatar
Advanced Member
"When will it end? (Problems) "
When you trade your car in... get used to it. It's a GM vehicle.
Old Sep 28, 2006 | 03:19 AM
ACE1252's Avatar
LOL, the above kinda sums it up. I like my '96 Z28. It has never left me on the side of the road, but it has had it's problems....and I still have to get the driver's side door hinge replaced(not tackling that one....leaving it for body shop....I don't have a good way to handle the door).
Hmm....problems from newest to oldest in 7 years...
-Window regulator's bolted to door...rivets loose, mounting holes "walloed"
-2 Power Window motors(just last week)
-4 Window stabilizers
-1 Driver's side top door weather strip
-1 Power steering pump
-1 Power steering rack
-1 Steering linkage
-1 Belt tensioner
-1 Temp sending unit(driver's side head)
-2 Power window motors
-1 Belt tensioner
-1 Bad Pinion bearing(all bearings in rear replaced)$500
-2 Warped heads(tore down; heads milled 0.005-0.010)$2,000
-1 Egr Valve
-1 Air Pump
My next big project is to pull the engine out of this thing.....looking to put headers, cam, roller rockers, and heads to this thing. Hopefully, I'll get started this winter on it.
Needless to say I have a Nissan as a daily driver now. However, I drove a 4th gen Camaro for 8 years straight though....4 years 3.8 V6, 4 years 5.7 V8.
Just to note, the only problem the 3.8 ever give me was bad plug wires....but I knew what I was getting into when I got the 5.7(been reading up here)....also, I had to have more horses and that V8 rumble!
Old Sep 28, 2006 | 09:21 AM
Lt1 and Ls1's Avatar
If you have an f-body you just have to get used to it!
jcamaro95lt1
Jan 24, 2015 08:21 AM
Jazsun
Dec 29, 2014 12:14 PM
Hurin
Dec 13, 2014 07:38 PM
