Cleaning the engine bay in a hurry??
Old Sep 24, 2006 | 06:25 PM
Resilient94LT1's Avatar
Does anyone have any tips or tricks on how to clean up the appearance of my engine bay in say... a day or two?
Such as, what can I use to clean the paint which has 12 years of crap on it, without it being so harsh a chemical that it goes THROUGH the paint (ie krud kutter, greased lightning).
Ways to improve the looks of like... the altenator, intake, heads, without taking anything off... just going over them.
Thanks!
Old Sep 24, 2006 | 06:43 PM
transAMdriv3r's Avatar
Re: Cleaning the engine bay in a hurry??
gum cutter or the hard way, brillo pad
Old Sep 27, 2006 | 08:49 PM
blown383's Avatar
Paint thinnner and some good elbow grease will remove a lot of the caked on crap. I also power washed the engine bay with hot soapy water through a 2400psi pressure washer. =)
-B
Old Sep 27, 2006 | 09:56 PM
-B
When you did that, what did you do with the optispark? I've heard stories.
Old Sep 28, 2006 | 03:26 AM
blown383's Avatar
Well I kinda cheated..... here is a picture of what I did.
Then I put the optispark in a pretty safe place where it won't get wet.
-B
Old Sep 28, 2006 | 12:13 PM
Rebelphotog96's Avatar
^^^ Yeah, you totally cheated. But, you are probably the first to put an LT1 in a Honda and in record breaking time!
Old Sep 28, 2006 | 01:44 PM
LOL granted I can't drop the motor out of the underside of my car, how would i go about covering the opti? Can I just reach down and put a garbage bag or two around it or something?
Old Sep 29, 2006 | 01:18 AM
blown383's Avatar
You can try the garbage bag technique but its hard when you hose off the motor water will flow all over the place. You might try and park the car on a steep incline so that all of the water flows back towards the tranny. FYI - My car just sputtered and wanted to die with even a little trickle of water on the opti.
-B
Old Sep 29, 2006 | 01:19 AM
blown383's Avatar
Also I have the world's 1st 14 cylinder Honda Accord on earth!
-B
Old Oct 1, 2006 | 01:00 PM
Brangeta's Avatar
What I wanna know is how you got a clothes line tied to a lamp to support the entire body of the car.
Old Oct 1, 2006 | 02:25 PM
Brangeta's Avatar
Hmmm... my money is still on "that's one hell of a strong lamp and clothes line!"
Old Oct 1, 2006 | 04:15 PM
69z-28's Avatar
lol.
i used greased lightening and a bottle of water. spray on the GL, then start scrubbing with toothbrush and papertowels then spray some water, and keep goin at it. basically rinsing off the GL and the grime that you scrub off. took me about 4 good hours to do my entire bay. was well worth it tho.
Old Oct 2, 2006 | 09:41 AM
Which GL did you use? I remember using the in the past, but it was tough enough to cut through paint for sure. I may have been using concentrate, however. I just want to get everything nice and clean and still have a running car and paint in the end.
Jazsun
Dec 29, 2014 12:14 PM
formula218
Dec 2, 2014 04:27 PM
kandied91z
Aug 4, 2002 02:53 AM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
