master cyl
Old Sep 24, 2006 | 03:52 PM
blackz151's Avatar
master cyl
Witch line comming out of the master cyl is the front brakes? The front one or the rear one. The line lock i have with the pre bent lines is the rear one but my dad swares up and down the front it for the front and rear for the rear
Old Sep 24, 2006 | 05:42 PM
Severous01's Avatar
Re: master cyl
should be etched in the cyl...if i remeber correctly. all should be etched fr fl rr and rl.
Old Sep 24, 2006 | 05:52 PM
blackz151's Avatar
Re: master cyl
thanks ill take a look
Old Sep 24, 2006 | 06:00 PM
respectirocz's Avatar
Re: master cyl
when you press on the brake pedal, you push in the rod on the master cylinder
the first half of the cylinder that gets pressure goes to the front brakes, the second half goes to the rear brakes
when you look at it from under the hood its backwards
so the brake line closest to you is for the rear brakes and the one closest to the firewall is for the front brakes
Old Sep 24, 2006 | 10:32 PM
Re: master cyl
Yep... only two connections on the master cylinder.... back connection to the front brakes (where your line lock goes) and front connection to the rear brakes.
Old Sep 25, 2006 | 12:31 AM
blackz151's Avatar
Re: master cyl
thanks alot
G-BODYT56
Jan 14, 2022 11:14 PM
cmsmith
Sep 14, 2015 09:09 PM
Daluchman1974
Sep 11, 2015 06:12 AM
1slow93z28
Sep 1, 2015 06:22 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
