Low coolant light???
Old Sep 23, 2006 | 10:12 AM
Lt1 and Ls1's Avatar
On my 98 trans am, the low coolant light started coming on. I checked the radiator and it is full. I dont see any leaks or anything. I dont have the owners manual but it is the red light with the water and the arrow pointing down. Do you think maybe just a sensor is bad? It doesnt get hot?? Thanks in advance Kara
Old Sep 23, 2006 | 10:45 AM
30thZ286speed's Avatar
Re: Low coolant light???
My car did the same thing, the sensor is probably dirty, a coolant flush should take care of it.
Old Sep 23, 2006 | 10:55 AM
95GRNZ's Avatar
Haven't really heard too many issues on the sensor in LS1's, but with LT1's it is a very common problem.
The sensor is about 20-30 bucks and is very easy to replace. Or, you can just unplug the connector to the sensor.
Old Sep 23, 2006 | 10:56 AM
Dirty or bad low coolant sensor.
This has got to be the most frequently asked question about these cars. I see a post nearly every day.
Old Sep 23, 2006 | 12:14 PM
CamaroFan71's Avatar
When I bought mine it was about $50 from autozone.
Old Sep 29, 2006 | 07:29 AM
Cool thanks
Old Sep 29, 2006 | 08:35 AM
kick Z tail out's Avatar
Yep, for some reason it's no shock to hear about this on a LT1 car... But it just dawned on me that this is probably the first time I've heard of it on a LS1.
Old Sep 29, 2006 | 01:02 PM
6SpdLT1Z's Avatar
I unplugged my low coolant sensor because I'm too cheap to spend $50 on a sensor.
Old Sep 29, 2006 | 01:11 PM
LT1 sensor should be less than $30 from the discount part sources that Shoebox lists on his website.
Old Sep 29, 2006 | 01:38 PM
davidz28guy's Avatar
ive been driving around with the light on for months, wheres the sensor at so i can unplug?, i never bothered looking for it
Old Sep 29, 2006 | 04:54 PM
MysticTeal95Z28's Avatar
My low coolant sensor for my car was $ 38 from the local dealer , got it without tax though.
Old Sep 29, 2006 | 05:19 PM
Yeah mine is on a Ls1
Old Sep 29, 2006 | 05:46 PM
2001NBMZ28's Avatar
IMO just disconnect it - light stays off. Don't have one on my car, think GM took them off our cars in '00?
Old Nov 2, 2006 | 08:15 PM
stone4779's Avatar
the coolant temp sensor is $9.99 at OReilly's with a lifetime warranty????
Check it out....
Old Nov 2, 2006 | 08:17 PM
ulakovic22's Avatar
Low Coolant Sensor and Coolant Temp Sensor are two different sensors. Low coolant is a square sensor under the radiator cap, coolant temp sensor is in the head and on the front of the water pump.
