Replacing all the clutch hydraulics..master cylinder?
Old Sep 22, 2006 | 07:18 PM
Jazsun's Avatar
I got the complete kit from gm, pre bleed and am trying to see if the hydraulics are the reason why my clutch wont fully disengage. I know how to take everything else off except the master cylinder. Is it best to remove the brake booster before doing anything? When removing the booster I dont have to disconnect any brake lines right? Any help on removing it?
Old Sep 22, 2006 | 08:08 PM
MEAN LT1's Avatar
Re: Replacing all the clutch hydraulics..master cylinder?
I just got done doing this. I didnt have to remove the brake booster or the lines. I'll admit I initially thought I would have too but it wasnt required. Once you take out the bolts from the inside of the U-bolt, I took a little hammer and evenly tapped the ubolt out. I then was able to grab the slave from the underside and was able to pull it out. Good luck.
Old Sep 23, 2006 | 03:49 PM
Belongs on the "Drivetrain" forum.
Ringmaster72
Mar 19, 2015 03:32 PM
BPS
9
Mar 5, 2015 10:51 PM
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
siguy
Nov 27, 2014 10:07 AM
