trans problems
Old Sep 21, 2006 | 06:44 PM
94z2896vette's Avatar
trans problems
This is like the 6th transission this car has gone threw . I had a motor swap from a 96 lt1 vette motor to my 94 z28 . My transmissions will run fine for a while and then start slipping or loseing gears in it . What might this be caused by . It really makes me wonder because I am tired of spending money on the damn car . And with the trans like that . Any comments shall help i would apprecaite it
Old Sep 21, 2006 | 07:03 PM
96capricemgr's Avatar
Re: trans problems
OK so for starters you swapped in for all practical purposes the same motor. Which computer did you use and which tranny. 94 was not PWM 96 was that is a serious conflict that would need addressing, can be made to work but needs attention to do so.
Also relatively few shops are competent as far as building this tranny for any performance use.
Old Sep 21, 2006 | 07:38 PM
supergt99's Avatar
Re: trans problems
i have the same prob, would like to know as well.
Old Sep 21, 2006 | 08:06 PM
Re: trans problems
its a 94 pcm * stock computer * not the 96 . Would I have to get a 96 vette pcm ...
Old Sep 22, 2006 | 07:23 AM
Vince @ FLT's Avatar
Re: trans problems
Are you still running the 94 trans with the 94 computer? This is important as stated above.
Old Sep 22, 2006 | 10:53 AM
Re: trans problems
Yes it is the 94 computer in the 94 camaro . It is a 96 vette lt1 motor . And I was wondering why .
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
PCLZ28
Dec 24, 2015 05:19 PM
Sarahrope64
Nov 27, 2014 11:17 AM
siguy
Nov 27, 2014 10:07 AM
