Drag Radial Questions
Old Sep 13, 2006 | 10:12 AM
350pride's Avatar
I thinking about purchasing a set of 315/35/17 Nitto 555r's. My concern is my rearend. But I thinking that I could control the amount of traction I got by adjusting the amount of air pressure in the tire, and since I dont have much side wall that will also help.
I only want to cut 1.8-1.9 60fts. (AND THATS IT). My Mods are in sig. But for your convience I have a hotcam, 1.6 rr, bolt-on, A4 with stock gears.
So im i correct in what im thinking and do you think the Nittos will obtain my goal, or do you think theyll give me WAY more traction than that, thus causing me to break something?
Thanks for your help,
pride
Old Sep 14, 2006 | 08:13 AM
kick Z tail out's Avatar
Re: Drag Radial Questions
A4 with which stock gears? 2.73 or 3.23?
Anyway, it doesn't really matter... Automatics don't load the rear end up with an incredible amount of shock on the launch like manuals do. You'll be fine. If you had a 4000 stall, or a transbrake... then maybe you can start worrying again.
I've run DRs plenty of times on my 10 bolt, with a crazy, hard-shifting race built automatic and 3.73s out back.
Old Sep 14, 2006 | 09:07 AM
Honda Hunter's Avatar
Youll be fine.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
CARGASM
Sep 4, 2002 11:17 AM
vic_wants_an_SS
Jul 30, 2002 11:38 AM
