whattya think of this idea
Old Sep 1, 2006 | 11:59 AM
cjmatt's Avatar
Well considering that the stock vortech bypass valve only holds about 10-10.5 psi of boost. I was considering using my 18 psi pulley in order to get the boost up early on then just let anything over 18 vent off to the atmosphere. Also, has anyone ran their maf after the BPV on a vortech? where did you put it?
Old Sep 1, 2006 | 01:14 PM
cjmatt's Avatar
Re: whattya think of this idea
I was thinking of putting my maf before the elbow to the throttle and welding up the bypass valve hole and moving my bypass to before the aftercooler in order to keep from heating up the aftercooler.
Old Sep 1, 2006 | 02:10 PM
Roadie's Avatar
Originally Posted by cjmatt
...and moving my bypass to before the aftercooler in order to keep from heating up the aftercooler.
the blower doesn't heat air up. Heat is generated by the process of compressing the air. By having the bypass after the cooler, you are actually cooling it with fresh air when you are not making boost.
As far as your other idea, it takes power to drive the supercharger. You'll likely make boost lower in the RPM range, but lose peak power because you're wasting more to spin the blower harder, not to mention extra heat, wear and tear on the headunit, etc.
Old Sep 1, 2006 | 02:36 PM
cjmatt's Avatar
but wont the air continue to get warmer and warmeras it cycles repeatedly through the blower?
Old Sep 1, 2006 | 03:16 PM
Roadie's Avatar
you were talking about running your MAF after the BPV. If so, you'd vent the BPV to atmosphere. There's no need to recycle the air if it's not metered.
Old Sep 1, 2006 | 05:31 PM
OBE1 95Z28's Avatar
The blower is a compressor and therefore always heating the air. Therefore a blow-off valve should be located before the aftercooler if you decided to relocate the MAF to just before the TB.
Old Sep 1, 2006 | 07:32 PM
boosted-lt1's Avatar
I really like this idea.
Although, if you're venting to ATM...can we quantify the heat generated when the blower is not loaded?
-Scott.
Old Sep 1, 2006 | 10:53 PM
OBE1 95Z28's Avatar
-Scott.
If you want to quantify it you can also attach a temperature sensor to the output of the BOV. The point I was making is the blower air isn't going to cool the aftercooler when not in boost.
Old Sep 2, 2006 | 02:19 PM
cjmatt's Avatar
Right, with an air to water, the only way itd cool the aftercooler was if the air coming from the blower was cooler than the water in the aftercooler, which isnt gonna happen. so rather than heat up my water unnecesarily, why not vent it before, plus you get the benefit of not messing with the mafs reading from turbulence
Girrrrl
Aug 20, 2015 09:26 AM
Girrrrl
Aug 20, 2015 06:17 AM
TGGodfrey
Aug 18, 2015 06:08 PM
Devinfoote87
Parts Wanted
Aug 6, 2015 05:05 PM
asilomar244
Jul 12, 2015 05:53 AM
