What Kind Of Couplings Are You Using On Your Blower?
Old Aug 28, 2006 | 10:21 PM
Shirl's Avatar
I'm going to change all of the couplings and picked up a black silicone one at Pep Boys and installed it tonight. It is Spectre brand. It's ok, but I need it to be a little bit tighter where the supercharger piping connects to the throttle body. I went with a 3 1/2" - 4" coupling. The band clamps keep it tight, but only time will tell when I boost it. Maybe I'll attempt to squeeze a "straight" 3 1/2" band instead.
Any suggestions on places (on the web) that supply these things? I'm not sure if I want to get more of them from Pep Boys or not. I'd like some custom-looking ones, if that's not asking too much.
Old Aug 28, 2006 | 10:52 PM
bowtiepwr's Avatar
Re: What Kind Of Couplings Are You Using On Your Blower?
>http://www.turbohoses.com/metal_piping.htm
Old Aug 28, 2006 | 11:32 PM
Shirl's Avatar
Thanks !
Old Aug 29, 2006 | 08:49 AM
97WS6Pilot's Avatar
Gates 24248 for the straight 3" hoses. I like the gates because it has an OEM look. 25psi working pressure. I bought the 2 ply hose but for a little more money you can get the four ply stuff. Here is a link but it can be found at NAPA. Its about $20 a foot.
http://www.gatespowerpro.com/Comerge...TOKEN=71875695
Old Aug 29, 2006 | 09:12 AM
Shirl's Avatar
Thanks, another good suggestion. I need something that's not going to pop off when I put the 6psi / 100 shot through it. The gates material looks similar to what I had on there. I just want to clean everything up cuz it's starting to get dirty looking after being on there for 8 years now.
Old Aug 29, 2006 | 09:24 AM
Roadie's Avatar
Usually the reason why hoses blow off is due to the clamps. If you use T-bolt or the expensive constant tension clamps, you won't have a problem. If you use worm-gear hose clamps, expect it to blow off.
Old Aug 30, 2006 | 08:30 AM
97WS6Pilot's Avatar
I've heard of some people who weld a bead on the throttle body to prevent the hose from blowing off. My holley 58mm throttle body came with a recessed area to prevent hoses from popping off.
Old Aug 30, 2006 | 08:42 AM
T/A KID's Avatar
hightempsilicone is another place. Always use T-bolt clamps.
Old Aug 30, 2006 | 11:12 AM
Roadie's Avatar
That's my only fear... My TB is a 52mm Edelbrock variety and it's smooth. I never had any problems with 6-7psi, but I'm not so sure it'll hold up with 3 times that... We'll see!
Old Aug 30, 2006 | 02:26 PM
bowtiepwr's Avatar
>just put some sheetmetal screws in it...
I may end up buying the NOS/Holley 58mm especially if it does have the "lip" aroung the mouth of it.
http://store.summitracing.com/partde...0&autoview=sku
Old Aug 30, 2006 | 03:40 PM
97WS6Pilot's Avatar
Does that have the passages built in for Nitrous? I was wondering why it was so expensive. Tbyrne has a good deal on Holley TB's.
http://www.tbyrnemotorsports.com/lt1catalog.html
Old Aug 31, 2006 | 03:16 PM
leadfoot94's Avatar
HightempSilicone.com / Siliconeintakes.com
All my couplers are 4 ply.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
SpeedJunkee
Jun 6, 2015 04:27 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
