Which 76GTS for a PTK kit???
Old Aug 21, 2006 | 07:43 PM
Houdini's Avatar
I have someone that can get me any turbo head unit from Precision Turbo for cost, and this new hook-up is the straw that broke the camels back... I've decided to commit to a turbo setup!
I need to choose a turbo that will work with all the PTK hot/cold parts, as thats the kit I will be using for this build. I see that I can get a 76GTS in varying combinations...
In GTQ or GTS trim... what the difference?
With housings that are...
On center .69 A/R
On center .85 A/R
Tangential .68 A/R
Tangential .81 A/R
Tangential .96 A/R
I assume the housings refer to them being "clocked" differently, which one work with the PTK kit?
And the A/R has to do with spool time, again which one? and why?
This kit will be going on a built 383, probably next year when I get done buying all the PTK parts. I know all about the need to build a complete car, you can't just go slapping on a turbo and expect nothing to break. I already have a Mcleod street twin, full bmr suspension, frame conectors (a Wolf 6-point cage to follow), Strange S-60 rearend with chrome-moly drive shaft, twin in-tank pumps (to be installed this winter), and a host of other supporting parts. About the last thing left on my list now is to build some power, and that's what I seek to do.
Just need a little help from the Pro's on the board...
Old Aug 22, 2006 | 11:02 AM
JZ 97 SS 1500's Avatar
Re: Which 76GTS for a PTK kit???
You will need the GTS with a .96A/R and Tang. housing.
Old Aug 22, 2006 | 11:17 AM
RealQuick's Avatar
Dont listen to Jose, he doesnt have a clue.
What you need is a GTS with a tang. .96A/r housing
Wait a sec...
In all seriousness, Jose has alot of knowledge, especially with what works with the PTK kit.
Old Aug 23, 2006 | 09:05 PM
leadfoot94's Avatar
I have a PT-76GTSHP: .96 A/R, Ported intake compressor housing.
Old Aug 23, 2006 | 09:35 PM
jerminator96's Avatar
Just for learning's sake would any of you mind explaining why that is the ideal housing to go with?
Old Aug 23, 2006 | 10:16 PM
Cause that is the largest offered on a 76GTS unit.
Jose
Old Aug 23, 2006 | 10:23 PM
Jose
Haha, well I hear ya, bigger is usually better. What about spool time? Is that based off of the 383, or would that housing be good for a 355 as well? What about heads, would it matter whether you had a huge set of AFR's (say 230cc) as opposed to ported stock castings?
Thanks,
Jeremy
Old Aug 23, 2006 | 10:32 PM
Thanks,
Jeremy
You will see boost at around 3500-3800 on the street depending on the setup. You want a .96A/R with either cube. As for heads.....the larger the heads, the less boost you have to run to get to your target hp level.
Old Aug 25, 2006 | 07:59 AM
Is 3500 max boost or just noticeable boost? It seems a little high for my liking.
Old Aug 25, 2006 | 09:04 AM
RealQuick's Avatar
max
Old Aug 25, 2006 | 09:21 AM
Correct, that is max boost. You'll see positive boost well before 3500.
lt1xondeck
Mar 18, 2016 07:22 PM
karpetcm
Aug 14, 2015 03:02 PM
RX Speed Works
Jul 24, 2015 02:25 PM
LeftoverChinese
Jul 23, 2015 03:57 PM
Jlo
Jul 22, 2015 05:00 PM
