new caliper
Old Aug 15, 2006 | 08:36 PM
SpeedDemon02SS's Avatar
new caliper
I have to get a new caliper for the front passanger side. The bleed valve broke off inside, and the easy out snapped in half.
Where is the best place to get one? I only need the outer caliper, not the valves, pistons, boots, pins, bolts, or caliper bracket. can i get it from gmpartsdirect.com?
also, if i got one from autozone, what is the difference between the higher price and lower priced one?
Old Aug 17, 2006 | 04:20 PM
Severous01's Avatar
Re: new caliper
cheapest is probably autozone or advance. they have them in stock and you wont be charged core if you bring yours with you. it's only like 25 bucks.
Old Aug 17, 2006 | 04:40 PM
Re: new caliper
i dont really want a crapy caliper though. i got one from gmparts direct for 80bux.
Old Aug 17, 2006 | 08:36 PM
z28chrizz's Avatar
Re: new caliper
I had to buy one from advanced... its a rebuilt oem or new PBR caliper... seems to do the job just fine so far...
Old Aug 20, 2006 | 12:53 AM
Severous01's Avatar
Re: new caliper
well, there are opinions about this. i see it as i've sent them a core...so they're rebuilding one from an OEM unit and re=selling it. that's my opinion.
others say that the rebuilt's suck. i dont think so. the factory brakes suck to begin with and if you want a stock replacement the that's fine. i'd go with the lsx upgrade. for 80 bucks you could get 2 calipers. then all you'd need is pads...dont skimp out here.
Old Aug 20, 2006 | 09:10 AM
Re: new caliper
i have an ls1, so i aready have the bigger breaks. i decided to get a cheap one from advanced. then in a few months, im gonna upgrade to a c5 setup. i already havec a set of eradispeed c5 rotors. so i am half way there.
Henson071
Sep 18, 2015 04:01 PM
force10
Jul 30, 2015 04:56 PM
alphaauto
Jul 26, 2015 04:40 PM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
