brake bleeding problems
Old Aug 15, 2006 | 12:46 PM
j0n's Avatar
j0n
This past weekend i put a new engine in(went out the bottom so i unbolted all the brake lines) and did a rear swap so today i went to bleed my rear brakes and when pumping the brake pedal it doesnt get stiff at all...and when i open the bleeder screws there's no air escaping, just brake fluid comes out the screws.
Also, when the brakes are pressed the rear calipers dont clamp the rotors at all
any ideaS?
Old Aug 15, 2006 | 01:02 PM
95z383lt4's Avatar
Re: brake bleeding problems
When I reinstalled my motor and rebuilt my rear, I had disconnected the brake lines at the manifold in the front and near the fuel filter in the rear. If you did the same, you have to push out all the fluid between those break points and the calipers before the introduced air can escape. Don't forget to refill your resevoir from time to time and make sure your e-brake is off. I have traction control and abs and that did not cause any trouble.
Old Aug 15, 2006 | 01:05 PM
j0n's Avatar
j0n
AH ok that makes sense...ill go try again
Old Aug 15, 2006 | 01:14 PM
GetaZforgetGT's Avatar
See if this helps.
http://web.camaross.com/forums/showt...leeding+brakes
Old Aug 15, 2006 | 10:46 PM
oneslowz28's Avatar
just go get a hand held vaccume pump made for bleeding brakes and pump untill u see air and pump some more. it makes bleeding the brakes on thses cars so much easer
Magenta_Hearts
Mar 25, 2015 10:24 AM
dluna333
15
Mar 13, 2015 12:30 PM
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
