Are sub frame connectors a good idea with the fuel trap door mod
Old Aug 15, 2006 | 12:25 PM
97ta9's Avatar
Does the trap door fuel pump mod decrease structual ridgity in 4th gens? Since I did this mod my rear hatch seems to squeck a little going over large bumps. Do you think that 2 point or 3 point subframe connectors would help with this, or am i just being paranoid?
Old Aug 15, 2006 | 01:11 PM
tractionisovr8ed's Avatar
Re: Are sub frame connectors a good idea with the fuel trap door mod
I had subframes on the car before did the same fuel pump door mod and I haven't noticed any squeaking or any difference. The subframe connectors probably do help for this, as well as many other things.
Old Aug 16, 2006 | 09:38 AM
Bud M's Avatar
If your hatch squeaks, adjust the 2 rubber stops in the rear corners of the hatch. Un screw them a little to keep the hatch from moving when you go over bumps. SFCs won't affect that squeak.
Old Aug 16, 2006 | 10:40 AM
97ta9's Avatar
Thanks for the idea bud. It just seems that since it just started doing this after the trap door mod, that there might be a little side to side twisting in the rear of the car. If adjusting the hatch doesn't work than I will try sfcs.
Old Aug 16, 2006 | 10:44 AM
Grims's Avatar
The trapdoor mod doesn't effect structural integrity, I can't see SFCs helping.
Old Aug 16, 2006 | 02:33 PM
mcnamaraSS's Avatar
Smile Re: Are sub frame connectors a good idea with the fuel trap door mod
Is your squeaking sound coming from either side or middle. I was having a squeak that sound like it was coming from rear toward the right. Pulled cover off the tire compartment and checked tightness of tire holder. Squeak-squeak, took out tire and it was causing contact between tire and metal tube that antenna wire runs up to rear Quarted inner pannel. Took a piece of water pipe insulator tube I had in basement and wraped around full length. "NO SQUEAK". Give it a try.
Old Aug 16, 2006 | 07:29 PM
Greed4Speed's Avatar
Just tightening the thing that holds the spare tires stopped that squeak for me.
Old Aug 17, 2006 | 03:56 PM
97ta9's Avatar
It's not the spare tire/ jack, i took it out and did the same thing. It's seems like the rear hatch is shifting a little bit over bumps. I adjusted the rear hatch rubber stops and it seemed to help some. I know a lot of people have done this mod before and was interested to see if anybody else experianced anything similar.
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Dec 23, 2014 07:52 AM
Pandamonkey
Aug 23, 2002 12:02 PM
Skull Leader
Aug 10, 2002 11:01 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
