What tires to get?
Old Aug 15, 2006 | 10:18 AM
Gripenfelter's Avatar
What tires to get?
I need a set of tires for 17x9.5 and 18x10.5 rims.
What kind and what width/profile should I go with?
275? 265?
295? 315?
Anyone recommend a good set?
Firestone Firehawks?
BFG KDWs?
Nittos?
Old Aug 15, 2006 | 11:16 AM
x7x7's Avatar
Re: What tires to get?
my fronts are 265/40/17 and my rears are 295/35/18. should be here today. I'll bring the car by after I install them, after work.
Old Aug 15, 2006 | 12:13 PM
Sounds good. That's the size that was recommended to me. James has 315s and his fender cuts his tread and sidewall on turns and bumps. He still has to still roll his fenders.
what tires did they send u?
Old Aug 15, 2006 | 12:52 PM
x7x7's Avatar
Firestone Firehawk Wide Oval. I'm hoping with this offset/size I won't have to roll the fender lip.
Old Aug 15, 2006 | 01:10 PM
I think I might have to get the same tire because BFG KDW doesn't come in the right size for the fronts and Nittos will wear down very fast on the rears. They are softer on 18s than on 16s...weird.
Old Aug 25, 2006 | 12:29 PM
rahusband's Avatar
ok, got a question. I'm getting a set of 18 by 9.5' for my rear's what is the maximum width i can go on those rims and were can i get em at??? 295/305 possibly??
Old Aug 25, 2006 | 02:39 PM
The "FAQ" stickied at the top of the page is your friend.
245/40-18: 25.7” diameter; 8.0” – 9.5” wide wheel
255/40-18: 26.0” diameter; 8.5” – 10.0” wide wheel
265/35-18: 25.3” diameter; 9.0” – 10.5” wide wheel
275/35-18: 25.5” diameter; 9.0” – 11.0” wide wheel
285/35-18: 25.9” diameter; 9.5” – 11.0” wide wheel
295/35-18: 26.2” diameter; 10.0” – 10.5” wide wheel
315/30-18: 25.5” diameter; 10.5” – 11.5” wide wheel
335/30-18: 26.1” diameter; 12.0” – 13.0” wide wheel
Old Aug 25, 2006 | 05:31 PM
CamaroRacing12's Avatar
would 335/30/18 fit on a 93-97 f-body? i have never seen it i was j/w and do 315's fit really well on 10.5inch wide rims? or is iy better to go with 11 inch?
Old Aug 26, 2006 | 11:26 AM
People have put 335/35-17's on a 4th Gen. How they fit without major hammering is puzzling, but its been done. Check with user "kmook". The purpose of the FAQ is not to tell you what fits on a particular body style. The purpose is to tell you what tire fits on what wheel width, according to most manufacturers.
As far as the wheel width for a 315/30-18, the numbers in the FAQ are based on a review of the recommended wheel widths for several manufacturers. If they say their tire would work on a 10.5-11.5" wide wheel, I personally wouldn't question it. Whether it "looks" best on a particular wheel is highly subjective, and that's not the purpose of the data included in the FAQ.
Old Aug 27, 2006 | 09:10 AM
Dave '97 Z28 M6's Avatar
Originally Posted by Injuneer
People have put 335/35-17's on a 4th Gen. How they fit without major hammering is puzzling, but its been done...
Yeah, you and I have both done 17x11's so we know there's very little clearance with 315's, let alone 335's. But as you pointed out, it's been done.
Old Aug 27, 2006 | 10:13 PM
gt_biker13's Avatar
I would do a 275/40-17 and 285/35-18 and get some Goodyear F1 GSD3s, you have more choices in tires if you go with a 285/35 in the rear. You wont have as many problems as you would with the 315/30s. I have 315s on my car and the damn things still rub after doing EVERYTHING in the FAQ
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
Daluchman1974
Sep 11, 2015 06:12 AM
scottcba1
Sep 8, 2015 09:52 AM
rideordie
Sep 7, 2015 08:22 AM
Slayer
Jul 4, 2015 03:06 PM
