Still Existing Problem with Power Output in my car
Old Aug 15, 2006 | 04:06 AM
baroncraze's Avatar
Exclamation Still Existing Problem with Power Output in my car
I have a 2002 Camaro SS T-Top, live in southern NJ
Recent problem my battery indictor is continuing to run low, especially when the A/C is on high, the higher the cooling fans the lower the battery indictor falls - heading under 13 (the lowest number in white) and falls into the red zone, this happen more often in traffic and idling in city traffic.
The battery has been change - no improvement.
The alternator was pulled and change out - no improvement.
Figure it was faulty so replaced that one - no improvement.
Thought it was the grounding wire leading to the on board computer, replaced the on board computer - no improvement.
There is no problem with the engine sounds fine.
Full electric system check completed - everything checks out perfect.
The problem my mechanic tells must lie somewhere between the Cooling Fans and the alternator.
Any body got any clue what is happening with my car - can't take any long enjoyable joyrides.
So my car pretty much just sits in the driveway and doesn't go anywhere.
Can be also contacted at: baron_craze@yahoo.com
Injuneer
Dec 15, 2014 09:36 AM
USAirman93
Nov 24, 2014 03:37 PM
kandied91z
Aug 6, 2002 01:18 AM
Omega9
Aug 2, 2002 12:33 AM
Geoff Chadwick
Jul 31, 2002 12:07 PM
