shifter removal
Old Aug 10, 2006 | 01:27 AM
Fromaster's Avatar
shifter removal
i have an 86 camaro automatic, im wondering how do u remover the shifter lever so that you can take the console off?
Old Aug 10, 2006 | 01:41 AM
Capn Pete's Avatar
Re: shifter removal
If you pull the shifter back to 1st, look on the front of the shifter ****, and you should see a "staple" sticking into the ****. If you pull that staple, the shifter **** will pop right off. Usually you can get behind them with a small straight screwdriver.
.....hey, I even found you a picture!!! (I'm pretty sure the '86 will be the same idea)
http://afrashteh.com/tranny_pics/day1/dcp_0814.jpg
Old Aug 10, 2006 | 06:14 AM
Šenial™'s Avatar
Re: shifter removal
I dont think those are there on the z28's or iroc's, not sure what you have, but what capn posted was a picture of a **** off of an rs, i believe the ball on the z28 and iroc's are more ball shaped and should just screw off
Old Aug 10, 2006 | 12:14 PM
Capn Pete's Avatar
Re: shifter removal
Automatic ***** never screw off??
I just had another thought though ..... the factory shifter in my old '81 Z28 was a little different. To remove it, you have to pop off just the "button", and then down inside the top of the handle (underneath where the button was) there's a snap ring that you need to get out. Obviously snap ring pliers would be the best, but you can usually use a straight screwdriver to get one side started and pop the thing out. Then the **** will pop off.
I don't know which style was used in 3rd-gens?? I'm sure one of the 2 methods will work.
BTW, that shifter **** pictured above is out of a 4th-gen LT1/LS1 car.
R@mpage
Apr 20, 2015 10:02 AM
Apr 16, 2015 09:57 AM
BigWil
Mar 29, 2015 12:24 PM
karpetcm
Feb 9, 2015 09:21 PM
