Can u overide the Trans Perform Button so it's always on?
Old Aug 9, 2006 | 12:11 PM
MikeTR's Avatar
I did a search and found nothing like this....when you get in the car, the Transmission Perform button is OFF. I would like to have it ON all the time and be able to turn it OFF with the switch. Does that make sense? LOL
TIA,
Mike
Old Aug 9, 2006 | 01:02 PM
2QUIK6's Avatar
Re: Can u overide the Trans Perform Button so it's always on?
Easiest thing to do would be to swap the "normal" transmission tables with the "perform" transmission tables in the PCM programming.
Easy to do if you have an editor such as Tunercat.
Old Aug 9, 2006 | 02:05 PM
MikeTR's Avatar
LOLOL I guess I'm pretty dumb! I have to send it out to MADZ or PCM4LESS to get re-programed for the new gears! I guess I can just tell them to do something with it and forget it?
Mike
Old Aug 9, 2006 | 04:37 PM
2QUIK6's Avatar
Mike
Sure, they should be able to do that easy enough.
I think there's about 4 different tables that have to be swapped with each other....just going from memory..there may be a couple of others I've never played with.
Upshift/Downshift
Time in gear for upshift/downshift
TCC lockup
TCC unlock
There's actually several sets of these, a "normal", "performance", "hot/hi temp", and I think a "Manual mode".
I don't know that the later 2 are ever used.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
PCLZ28
Dec 24, 2015 05:19 PM
