OBD1 conversion ?
Old Aug 6, 2006 | 09:39 PM
97 LT1formula's Avatar
OBD1 conversion ?
I have a 97 Formula and wanna do the OBD1 conversion. If I get a computer from a 94-95 F-body is it just plug and play? I know to tune out the knock sensor or get one from that year.
Old Aug 6, 2006 | 09:56 PM
Re: OBD1 conversion ?
Its also possible to make in internal modification to the OBD-I PCM to allow it to function with the 100kOhm OBD-II knock sensor.
Old Aug 6, 2006 | 10:02 PM
so itll work just by pluggin it in and tuning out the knock sensor or putting the resistor in for the obdII sensor?
Old Aug 7, 2006 | 09:26 PM
Dave '97 Z28 M6's Avatar
What Injuneer is saying is that there is a way to modify the internal circuitry of an OBDI PCM so that it will simply plug into the car and function properly using the OBDII knock sensor. I'm not sure how it's done, but that is how my OBDI conversion PCM was prepared by PCMforless. It *may* not be the sort of thing the average Joe should attempt - I don't know.
Replacing the knock sensor with the OBDI unit is easy enough. I would not tune it out.
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
tdigger9899
Sep 7, 2015 10:56 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
