AC help, dryer canister is hot to the touch!!
Old Aug 6, 2006 | 04:13 PM
Brians_TA's Avatar
ok I changed my expansion valve and started filling the system.the AC is still cycling on and off and not blowing coldand will only take about one can.. also the dryer reciever canister is HOT!!.. any ideas what it could be?? could the dryer canister be cloged..
Old Aug 6, 2006 | 04:40 PM
Bayer-Z28's Avatar
Re: AC help, dryer canister is hot to the touch!!
I'll be lurking. I've got the same problem.. Mine won't take refrigerant...
Old Aug 6, 2006 | 05:01 PM
Was the system evacuated? It's pretty much a must when you open the system to replace parts.
Old Aug 6, 2006 | 05:06 PM
Brians_TA's Avatar
I did not have it evacuated, but this is the same thing it was doing before I even broke the system open.. the mechanic said that I had a cloged expansion valve becuase every time the compressor kicks the high side presure goes off the chart and it kicks right back off.. well now I have replaced the expansion valve and its doing the same damn thing.. and from what I read the only other thing that can really clog is the drier canister..
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
WobblySausage
Oct 7, 2015 02:44 PM
MDZ28
11
Sep 24, 2015 09:15 AM
damnyankee36
Sep 9, 2015 07:06 PM
