to much boost? head gaskets went..
Old Aug 6, 2006 | 10:05 AM
flusz28's Avatar
last summer i had put the motor back together and i used felpro 1074 gaskets for my 1994 z28 with a s-trim. i should be seeing 6-8psi on this car. it has vortechs 3.125 pulley the size under the stock one and i have a brad brand intake.
car has been done for months cause of bad idle problems and i replaced abunch of stuff that didn't need replaced. then i found someone with a scanner a buddy of me got one and we were reving the car to try to keep it at a steady rpm since it was stalling out. then white smoke and we knew!! funny how i drove it for about a month after the dyno and i had no problems,but for 8months the car sat and wasn't started,so maybe dry rot?
do i need better head gaskets?
Old Aug 6, 2006 | 10:34 AM
CALL911's Avatar
Re: to much boost? head gaskets went..
I have heard of issues on Forced Induction cars with the Intake gaskets going bad, but not Head Gaskets.
I know several people (including myself) have used 3M adheasive to their intake gaskets to ensure a good lasting seal. I don't know if this could also be used on the head gaskets.
I believe I have the same head gaskets on my 95, and I have been running 15#'s of boost on a D1SC with no problems (as far as the head gaskets go), so that makes me believe your problem is elsewhere.
Old Aug 6, 2006 | 10:41 AM
flusz28's Avatar
so you think the felpro intake gaskets i used could be the problem and not the heads?
antifreeze was dumping out the exhaust though..
how the heck would i beable to tell if the intake gaskets were the problem and not the heads?? oil was full of antifreeze!
man- replaced my new opti thinking it was the problem and it wasn't. replaced new map sensor too... i just hope my brand new plugs and o2sensors aren't junk from acouple mins of trying to scan the car.
anyone need a opti? mine has 1000miles on it and worked perfect.
Old Aug 6, 2006 | 11:08 AM
flusz28's Avatar
Also acouple months ago i pulled the intake to port it for a throttlebody. so maybe you arew right that the ntake is the issue? stock felpro intake gaskets not good enough>?
Old Aug 6, 2006 | 11:46 AM
joe-96z1le's Avatar
Your problem sounds alot like a blown head gasket and/or a warped cylinder head. Suggest you pull the heads and check.
Old Aug 6, 2006 | 12:30 PM
Robs97Z28's Avatar
Cool Re: to much boost? head gaskets went..
it could be as simple as the head bolts are leaking. that is what happened on my stock motor. What did you use to sell the head bolts with? did you reuse the stock head bolts or did you replace them?
Old Aug 6, 2006 | 01:51 PM
OBE1 95Z28's Avatar
No coolant in the intake so that's not the source of your white smoke. Sounds like head gasket(s). IMO head gasket failures are usually the symptom, not the root cause of your problem. Detonation (ping/knock) is probably what made the head gaskets go.
Old Aug 6, 2006 | 10:27 PM
flusz28's Avatar
i used ARP head bolts. hmm the car sat for 8 months and i changed the oil and fired it up a month ago and one or two rockers/lifters was tapping and it wouldn't pump up.. car did backfire like twice on me and i have heard that can kill the head gaskets.
guys do i need better head gasket then the felpro 1074's for my setup?
a friend has a 97 z28 with nos and he caught backfire/detonnation and it took out his brand new head gaskets. sounds like my issue.
can my plugs and 02 sensors be cleaned and saved?
Old Aug 7, 2006 | 07:44 AM
CJ's Avatar
CJ
Head gaskets are not your problem.
You probably either have major detonation or a warped head. Has the car overheated any?
Old Aug 7, 2006 | 08:08 AM
flusz28's Avatar
two years ago at 140mph my water pump went out and by the time i got the car stopped it had over heated. i had a machine shop fix the heads cause they were warped. so the heads are fine,the car spent a hr on the dyno with them beating it and with a bad fuel pump and fouled plugs i pulled 400rwhp.
like i asked before - are these head gaskets good enough or do i need something better?
Old Aug 7, 2006 | 11:41 AM
CJ's Avatar
CJ
You do not need to upgrade your head gaskets. Theyre fine.
Old Aug 8, 2006 | 12:12 AM
94 NO TOP Z's Avatar
[QUOTE=flusz28]the car spent a hr on the dyno with them beating it and with a bad fuel pump and fouled plugs i pulled 400rwhp.
QUOTE]
Not the best thing for head gaskets there. I have had good luck with Cometics but, lots of people run the Felpros with a lot more boost than you without any issues. Need to fix the detonation problem it sounds like.
Old Aug 8, 2006 | 08:29 AM
RealQuick's Avatar
Get the tune worked out and get head studs.
Old Aug 8, 2006 | 08:33 AM
flusz28's Avatar
ah i was just going to ask if i needed head studs. i think thats the problem in general. car has a good tune on it, i had mixed up some plug wires on my delteq and it back fired while i was scanning it and found a bad tps sensor so that might have took what last leg my head gaskets had after the dyno time.
Old Aug 8, 2006 | 08:37 AM
flusz28's Avatar
ARP studs okay? pricey thats for sure..
