pipe over axle??
Old Aug 2, 2006 | 10:41 PM
touch109's Avatar
pipe over axle??
I was wondering why the pipe over the axle has a bend on it. i have the center mounted exhaust system from factory, then i added the loud mouth resonator and noticed the pipe was bent. looked at slp website and couldnt tell if the loud mouth pipe was bent... went to a muffler shop and they said if i changed the pipe it would hit the car...
Old Aug 2, 2006 | 11:32 PM
MyShibbyZ28's Avatar
Re: pipe over axle??
What exactly are you talking about? All cars had a single bent pipe over the axle that either went into a muffler with one outlet, or a dual outlet wether the dual was in the middle, to one side, or both sides.
Old Aug 3, 2006 | 06:41 AM
teke184's Avatar
are you saying the bend over the axle has a "dent" in it.
cause if it's mounted correctly...it shouldn't have it or need it
Old Aug 3, 2006 | 09:21 AM
anaik's Avatar
Not sure if this is what you mean, but the bend is for suspension travel. Namely the rear axle.
Old Aug 3, 2006 | 11:31 AM
touch109's Avatar
thats what i meant was the bent on the pipe the goes right over the axle.. i just wanted to know if all exhaust systems pipe that go over the axle have that bend...
Old Aug 3, 2006 | 02:35 PM
teke184's Avatar
unless you can figure out a way to run the exhaust pipe through the axle
Old Aug 4, 2006 | 11:16 AM
touch109's Avatar
i dont mean the curve that goes over the axle i mean the pipe that is curved over axle has a bend on it right over the panrod bar
2QUIK6
Sep 17, 2016 02:31 PM
surreybrad
Aug 10, 2015 09:34 AM
Devinfoote87
Jul 30, 2015 09:54 AM
Jlo
Jul 29, 2015 03:52 PM
realistyc
Jul 28, 2015 07:32 PM
