Help W/ No EGR LS6 intake on 98 Z !!!
Old Nov 11, 2002 | 01:43 PM
coolguy's Avatar
Question Help W/ No EGR LS6 intake on 98 Z !!!
I have a 98 z-28, i bought a LS6 intake with no EGR , there is no hole after the trottle body to put that tube in right. soo is there a way i can by-pass it or hook it up in another way with out useing Ls1 Edit??? thanks
Old Nov 11, 2002 | 07:08 PM
danziger's Avatar
Unhappy
Nope. You can just remove the EGR and use a block-off plate, but without LS1 Edit you will have a SES light. It won't hurt anything, just be annoying. I removed the AIR and EGR and the car runs better than ever.
Old Nov 15, 2002 | 06:55 PM
JohnM's Avatar
EGR FIX
The fix for the Z06 intake I used was to find 01 vin number and re-flash my pcm with the newer calibration. The only major issues are: the other car needs the same gauges, gear etc.
Late model Ls-1's never had the egr valve. I made my own block off plate for the exhaust.
JohnM
Old Nov 18, 2002 | 11:40 AM
coolguy's Avatar
i went to the lingenfleter site and they had a adaptor for the egr on my intake .. would this work
Old Nov 18, 2002 | 03:29 PM
maddboost's Avatar
Well your best option is just to remove the EGR from the car all together it robs horsepower and obviously you are trying to obtain more. My buddy removed the EGR on is '00 Z and he didnt get a Check Engine light or anything. Also for blocking off your headers www.ls1speed.com sells EGR block off plates im sure other places sell them but this is the only one I know of. Also removing EGR pump will save you some weight I believe its located underneath one of the fuse panels under the hood, just follow the hose. If you do need to have your PCM reprogrammed you might as well have some custom tuning done for a little more you'll pick up idle quality and horsepower.
R@mpage
Apr 20, 2015 10:02 AM
99TransAmWS6
Mar 22, 2015 11:00 PM
birdblack
Dec 30, 2014 06:59 PM
hotrodyou1
Dec 20, 2014 10:05 PM
stanghunter211
Aug 29, 2002 03:04 AM
