Re-Assembling the drivetrain
Old Jul 21, 2006 | 11:26 PM
Jazsun's Avatar
Couple of questions: Any help is greatly appreciated.
1) Whats the best way to remove/install the flywheel? Just shuve a peice of wood in the teeth so it cant turn?
2) Where should I put grease? I bought some white lithium in a spray bottle and also have regular grease like the kind you put in ujoints etc.. Which kind should I use and where should I put it? How much?
3) If I am having the flywheel resurfaced do I need to put shims? If so were do they go?
4) Before installing things like the clutch/pressure plate/ flywheel I understand that they should be sprayed down w/ brake cleaner and wiped clean. Do you also spray the clutch?
4) Any websites where I can find torque specs for everything?
Old Jul 22, 2006 | 11:21 AM
Jazsun's Avatar
Re: Re-Assembling the drivetrain
I have everything off right now, im just waiting on taking the flywheel off, which is why I need some info on what I should use to stop it from turning.
Thanks.
Old Jul 22, 2006 | 01:45 PM
anaik's Avatar
Torque specs.
http://www.bfranker.badz28.com/fbody/torquespecs.htm
Old Jul 22, 2006 | 05:08 PM
96TurboTA's Avatar
Thanks.
I don't know of an easy way to do it. Just trial an error
Old Jul 22, 2006 | 07:58 PM
OBE1 95Z28's Avatar
An impact gun works if you have access to air. If not, a pry bar can be wedged between the ring gear teeth and the block.
Old Jul 22, 2006 | 08:36 PM
Jazsun's Avatar
K thanks, I put a new pilot bearing in today. I couldnt get it to go 100% flush its a hair sticking out still. It sounds and feels like it cant go back anymore. Is this normal? Should it be 100% flush? I tried hitting it pretty hard and it sounds like metal on metal like it cant go back anymore.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
WobblySausage
Oct 7, 2015 02:44 PM
War Engine
Aug 21, 2015 05:28 AM
alphaauto
Jul 26, 2015 04:40 PM
