M6 swap: Does a stock LT1 fly wheel need to be balanced when put on another lt1?
Old Jul 14, 2006 | 12:42 AM
Z28LT1_Just_Nasty's Avatar
Simple question, just doing some research before I do mine hopefully next month.
Old Jul 14, 2006 | 05:52 AM
rskrause's Avatar
Moderator
Re: M6 swap: Does a stock LT1 fly wheel need to be balanced when put on another lt1?
It will PROBABLY be ok.
Rich
Old Jul 14, 2006 | 10:16 AM
What issues could I run into if it's not balanced properly? Let's say I get a new flywheel entirely and I don't get it balanced. I'm just curious what would happen.
Old Jul 14, 2006 | 01:49 PM
OBE1 95Z28's Avatar
The stock LT1 flywheel is not neutrally balanced, therefore you can't have it balanced unless you're going to have the engine rebuilt and have the rotating assembly balanced. As Rich stated, you should be fine just bolting it up.
Old Jul 14, 2006 | 04:16 PM
RacingTiger04's Avatar
when i did the swap i had the flywheel that came off the engine from the a4 and had the one from the t56 car balance matched to the one from mine. just an extra precaution recommended to me by a member on here seeing as the LT1 from the factory is balanced by the flywheel, not sure if it helped any but i have no engine vibration so may be a worthy precaution.
Old Jul 14, 2006 | 05:02 PM
94EvilZ28's Avatar
Have it Zero Balanced...if you dont...throws off the way the engine and everything inside is balanced...get it zero balanced...
Old Jul 14, 2006 | 07:06 PM
OBE1 95Z28's Avatar
LT1 is externally balanced in the rear.
Old Jul 15, 2006 | 09:14 AM
J's 82's Avatar
I went from an auto to M6 with no balancing issues, just bolted up the flywheel and went, no trauma..
DON'T let anyone neutrally balance your flywheel.
CamaroHeed
Mar 18, 2020 09:50 PM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
ddr698
Jan 9, 2015 10:05 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
1LEThumper
Jul 14, 2003 12:45 PM
