Just Installed Edlebrock 52mm TB
Old Jul 8, 2006 | 02:49 PM
LtsRace's Avatar
Ive had it sitting in my room here for about 6 monthes. Not really serving its purpose on my dresser.
The throttle response is awesome!!! I feel a big difference.
Old Jul 8, 2006 | 04:53 PM
2000GTP's Avatar
Re: Just Installed Edlebrock 52mm TB
So it just bolted right up? You just swapped over the TPS sensor and IAC and everything worked fine? I've heard some people have had to readjust the TPS sensor.. did you have to do that by chance? I only ask because I still have my Edelbrock 52mm TB still sitting in my toolbox and it has been there since January. I bought it with the intent that I was going to be doing heads/cam this summer, but I did the nitrous instead. I'm tired of it sitting around though, its time I put it on along with the A/C delete pulley that has been sitting around since last summer!
Old Jul 8, 2006 | 06:44 PM
LtsRace's Avatar
Mine came with a new sensor, But yeah, thats all I did was bolt on and it started right up. I didnt expect it to be that easy, thats usually not my luck. It took me like 30 minutes tops. Since I did the throttle body bypass mod I didnt have to worry about any coolant getting on my opti.
Let me know that you think when you bolt your on!
-Joe
Old Jul 8, 2006 | 06:47 PM
2000GTP's Avatar
I have the TB bypass done on mine as well so that eliminates one less step. Maybe I'll give it a shot tommorow.
Old Jul 9, 2006 | 04:06 PM
GrayZ28's Avatar
way back when i put mine on it was just that easy. i have the holley 52mm TB. the kit came with longer bolts and the gaskets. i just had to swap over my sensors. LTsRace, glad to hear your happy with it, GTP, put that sucker on and let us know how it feels.
Garry
Old Jul 9, 2006 | 08:11 PM
bolek's Avatar
How is your tranny shifting with 52mm TB?
Did you notice any difference?
Old Jul 9, 2006 | 08:30 PM
Dave89IROC's Avatar
Originally Posted by Taintedz28
the tb has nothing to do with the tranny. it jsut adds slightly more airflow and better throttle repsonse due to it being able to open open 90* quicker
actually, it the TPS is off, it will effect the shifts
Old Jul 9, 2006 | 10:01 PM
bolek's Avatar
You might want to read this post: "Tranny problems due to aftermarket TB"
Old Jul 10, 2006 | 08:16 AM
TPS position and RPM affect line pressure. How much air flows for a given rotation of the blades alters engine performance - TPS vs. engine load/RPM relationship is altered. Changing to a larger throttle body can affect A4 transmission performance.
Old Jul 10, 2006 | 09:18 AM
transamdude95's Avatar
When I put my 52mm on my car, I had some issues... just required a bit of TPS adjustment, so it's not difficult to correct.
Nov 18, 2023 07:21 PM
lt1-xjs
Jan 17, 2015 07:52 PM
Queens94z28
Dec 20, 2014 09:11 PM
thenewkid
Nov 27, 2014 09:41 AM
94redform
Sep 8, 2002 03:27 AM
