Powerdyne User Within
Old Jun 26, 2006 | 04:30 PM
onetransam4u2nv's Avatar
I have a couple questions too all the powerdyne users, hopefully you can help. First of all i have a 95 formula m6 spec stage 3 4:10 lt4 hot cam kit,lt4km,madz tune, pacesetter long tubes 3inch y pipe not cats,borla cat back, i picked up a 6psi powerdyne charger pretty cheap and i was wondering if i install a racetronixs fuel pump will i still have to use the fmu? also will i need to get my ecm retuned before i run it?
Old Jun 26, 2006 | 04:40 PM
Sparkz28ss's Avatar
Re: Powerdyne User Within
with 6psi the racetronix pump should be fine....but you will need a retune and I would lalso ook into a set of bigger injectors
Old Jun 26, 2006 | 09:24 PM
30thTA0525's Avatar
if i were you id run the FMU..only way i would think you should even consider not running it is if you have a good tune FOR the SC.. even though you have the badass pump with the stock regulator its not gonna do you any good for Pressure at the Injectors
Old Jun 27, 2006 | 06:17 AM
yeah i will try it any idea what kinda presuure i should have?
Old Jun 27, 2006 | 03:03 PM
30thTA0525's Avatar
the stock FMU increases your pressure 8psi for every 1lb of boost
marlar98
Sep 12, 2018 07:18 AM
2QUIK6
Sep 17, 2016 02:31 PM
maverickmk
Sep 1, 2015 09:17 PM
FryedClutch
Sep 1, 2015 08:24 AM
mrwz28
Jul 8, 2015 09:11 PM
