spec stage 3 is worn out at 30,000 miles
Old Jun 18, 2006 | 08:51 PM
onthemat's Avatar
The disk is worn to the rivets and the pressure plate has some wear on it also. It was the 6 puck, carbon kevlar blend, and I thought it would last longer. What clutch does everyone recommend that has the same holding power or maybe a little stronger but might last a little longer?
I have searched plenty but would like a little more info. Can the pressure plate can be resurfaced and then I could just buy a stage 4 disk?
Any ideas?
Old Jun 18, 2006 | 09:05 PM
wrd1972's Avatar
Re: spec stage 3 is worn out at 30,000 miles
Spec will reline the disk for around $150-$200 or so.
Yes the PP can be resurfaced. I have done this with good results.
With respect to wearing so fast, my guess is lots of dumping and aggresive driving. Also you may be riding the clutch or maybe incorrect break in.
Did you resurface the flywheel when you did the install?
Old Jun 18, 2006 | 10:03 PM
onthemat's Avatar
Break in was the usual 500 miles and I'm real careful about not riding the clutch. Yes the flywheel was resurfaced when I installed it. Sure I'm aggressive with it from time to time but for the most part it is my daily driver and I drive fairly nice.
What milage are you guys getting out of a clutch like this?
Would a stage 4 last any longer or maybe a mcleod disk??
Any other disks that I could use with my old pressure plate?
Old Jun 19, 2006 | 12:44 AM
5.0THIS's Avatar
I'd say 30000 miles out of a performance clutch like that is respectable.
Old Jun 19, 2006 | 10:07 PM
onthemat's Avatar
Thanks for the replies. I went ahead and got an lt-4 pressure plate with the Mcleod disk. Hopefully it will last a little longer and not be as harsh.
DirtyDaveW
Mar 15, 2015 07:01 PM
Ws6Envy
Mar 3, 2015 04:31 PM
YellowTransAm350
Mar 2, 2003 03:38 PM
High HP TA
Sep 6, 2002 08:00 PM
