will a B-body PCM work in an F-body?
Old Nov 9, 2002 | 02:28 PM
AHARTZ28's Avatar
i am onverting an OBD2 car over to OBD1 and wanted to know if i woul be able to use a PCM from a B-body? i beleive i will not be able to flash an F-boy flash in corect it has a different set up or data?
TIA
Ryan
Old Nov 9, 2002 | 08:21 PM
DOOM Master's Avatar
I don't know that much about OBD2 to OBD1 swaps, but as far as the computers themselves, each OBD1 LT1 PCM (except those that use the EPROMs, like the 93Z) is exactly the same hardware wise. The difference is in the programming. All you need to do is flash your stock or modified file in and your set to go.
Old Nov 9, 2002 | 09:39 PM
drop top steve's Avatar
B & F swap, you'll want the correct trans. Y works in B&F but B&F well not work in a Y-body.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Jul 4, 2005 05:00 PM
